Imagine a World Without Cords
  • Imagine a World Without Cords
Blog Ultrasmall Qi LED HACK
  • Author Author: vsluiter
  • Date Created: 12 Dec 2012 10:29 PM Date Created
  • Views 1686 views
  • wireless_power
  • led
  • qi_standard
  • qi
  • wp_challenge_one
  • solution
vsluiter
vsluiter
12 Dec 2012
As you saw in the previous post I still have some boards left; I decided to do a real 'hack' to show how small you can make a Qi receiver. I soldered a Qi receiver circuit, and dremeled off the rest of the board. REAL PCB Hacking!
This setup worked, and I thought I'd make a QiLED (it's blue, so you could pronounce it as 'chilled' image )light. Another possibility to "integrate Qi in daily life".
The IKEA card (default credit card size) was added as a size reference; and look at how small the Qi receiver in itself can be! The width of the board is now 23mm, and it could even be trimmed a bit down if needed!
Qihuahua powered wall lighting
To show the power of light that's available with this small receiver I took two pictures, one of the small 15W lamp that I normally use in our living room, and one where that light is combined with the QiLED, which is using about 1 Watt: 1/5th of the available Qi power!!
QiLED Qihuahua lighting vs. 'normal' light
Left: with QiLED powered by Qihuahua! Great!
Right: without QiLED: boring, dull, nah....
Amazing how much light power comes from 1 LED.... And powering this thing was VERY easy!
Of course the QiLED is powered by the Qihuahua in my home, but it can be supplied by any Qi compliant transmitter.
  • johnsocm
    johnsocm over 13 years ago
    Very Nice to see it that small. I wanted to do the same thing and make a SUPER small version but looks like you beat me to it! Nice job!
    Chad
  • johnsocm
    Chad
  • vsluiter
    vsluiter over 13 years ago in reply to johnsocm
    Hey Chad,
    Yeah, I like small circuits image I remember seeing a very compact 4-layer layout somewhere in a Qi brochure/app note, but can't find it now.  I found it amazing that this cost me about as much space as a diode bridge, 2 caps and a 7805; the 'standard' solution for a  5V supply!
    Regarding 'making' a small version: to fit the receiver in the LEGO battery box I had already made a very small design, for this 'hack' I just had to chopp off halve the board (a bit exciting, I did it after soldering the components. Should have done it the other way around!)...  Anyway, to me this opens up lots of possibilities for power in small housings.
