Blog IP: 10 : Status Update
  • Author Author: ipv1
  • Date Created: 20 Jun 2014 2:17 PM Date Created
  • Views 1189 views
  • beyond_the_phone
ipv1
ipv1
20 Jun 2014
I was hoping the contest end date would be extended since the parts I requested have still not completely arrived.
As of now, my IOT Container is working, logging temperature and sending data happily over serial. I am taking the data and sending it over an XBEE and onto a beaglebone Black.
Now here is the magic, I am sending the data over wired ethernet using MQTT to a raspberry pi. A mosquitto server is running over the RPi which creates the message stream. I was also able to store data on a database as well using PHP.that would take the data as arguments to GET requests on the web server. Will be doing a demo video tomorrow...
The things done are:
image Container Circuit and Software
image Wireless communication to base station. I tried using the CC2500 solution but ran into problems with the word lengths.
image Beaglebone MQTT Code
image Battery Management on the Base station. This was basically a boughtout
image Connectivity to a server, I am using wired ethernet since the wireless CC3000 module never showed up.
What remains.
image GPS module. This has arrived, but I have not played with it yet.
image Wireless Internet Connectivity. The GPRS module will work with an arduino but I was hoping for a better CC3000 based solution.
I will post a Video tomorrow.
Thanks
    mcb1 over 12 years ago in reply to ipv1 +1
    I spent too much time on software and upskilling, along with a pile of other unrelated tasks that came up. Luckily I wasn't held up by supply and delivery issues. I get the impression that everyone would…
    Given your other projects/Challenges you're doing well.
    You've still got a few days and there is 24hrs in each ....image
  • ipv1
    ipv1 over 12 years ago in reply to mcb1
    Thanks for the support. It is much needed and appreciated.
    I was stuck for the longest time with battery management IC I2C Communication Driver Code. Over than now and moved to other goals... Thankfully I now have a dedicated student working on side projects which gives me some time to work on this again. I would like to finish this irrespective of whether I win or not.
    Many thanks again.
  • ipv1
    Many thanks again.
    I get the impression that everyone would like to finish their project.image and the information gained will help others with Wireless Charging.
    Every time I mention it, people are confused so IMO it should be called " Intelligent Inductive Charging ".
