Blog Waterproofing marine equipment - 07 - Receiver Design Considerations
  • Author Author: ForcisConnect
  • Date Created: 21 Apr 2014 10:46 AM Date Created
  • Views 3085 views
  • Comments 13 comments
  • beyond_the_phone
ForcisConnect
ForcisConnect
21 Apr 2014
This weeks post will be about my receiver board design. I already published the schematic a few weeks ago, as I wanted to make it available as soon as possible, just in case someone else could use it. But now I want to elaborate a little bit on the decisions I had to make for the receiver.
I have very closely based my design on the evaluation board receiver. There are different reasons for it: The first is to start with design that is known to work. This will help troubleshoot problems while assembling and testing these first units. The second reason is the required tuning of the resonant capacitors. In order to properly do it we have to measure the coils inductance at 100kHz and 1Vrms to then calculate with these values the capacitors. I don’t have a LCR meter, and the ones with these characteristics are quite expensive. So it’s best to stay close to the EVM values and coils, at least at first.
My goal is to achieve a waterproof enclosure. Because of it there will be no external power adaptor. In this way we reduce the necessary openings in the enclosure to none. All the corresponding circuitry from the evaluation board has been removed.
The temperature NTC resistor values were also taken from the bq51013B datasheet. A low temperature threshold of -10ºC on the low side and a value of 100 ºC on the high side seemed reasonable.
Another important adjustment is the current limit of the chip. I want to be able to get the maximum current of 1.0A out, so the corresponding resistor has been set to 75Ohm.
The chip also has different operating modes that can be selected by pulling high or low the EN1 and EN2 pins. The following table from the data sheet summarizes the possible combinations. In our case both are tied to ground.
So now I have a wireless power receiver. But for my waterproofing application I need not only a power receiver, but also a way to store the energy. This will be done with a Lipo battery. As mentioned by mcb1 these batteries are quite sensitive to overvoltage and wrong charging. Therefore I need a Lipo battery charger.  The bq51050B has essentially the same pins as the 51013B (the only difference is that OUT is called BAT and EN1 is called TERM, all the other pins are the same) and additional components, but includes a Li-Ion charger in the IC. This chip just seems perfect for my application. After having a look at the evaluation board for the bq51050B and noticing that it’s essentially the same as the one of the bq51013B I decided to make a PCB that could be used with both ICs. In this way I won’t need to order separate PCBs, which will save me some money, and the additional board area will be small. Depending on which IC gets mounted, some components will be left unpopulated, while others may be substituted with 0 Ohm resistors.
The only components I had to add to make the board compatible with both IC were two resistors between TERM (EN1 at the bq51013B) and GND. These will determine when charging will be completed. I selected a value of 2400 Ohm, which means loading will finish when current gets below 10% of the maximal value, in my case 1A.
I have also added a couple of 0 Ohm resistors in series with  FOD, ILIM, TERM and RECT resistors (R8,R9,R10,R12) in order to be able to add a second one in case I needed to change the resistor values to non standard ones afterwards. I got this suggestion at the TI Wireless Power Forum. (http://e2e.ti.com/support/power_management/wireless_power/f/693/t/333462.aspx)
I now finally have a complete receiver design!
Here is the BOM
Qty
Value
Device
Package
Parts
Description
Farnell Code
1
LED0603
0603
LED1
LEDs
1465991
2
  1. 0.01uF
CAP
0603
C5, C6
Capacitor
1817916
3
  1. 0.1uF
CAP
0603
C14, C16, C17
Capacitor
2146610
2
  1. 0.47uF
CAP
0603
C3, C4
Capacitor
2354077
1
  1. 1.0uF
CAP
0805
C15
Capacitor
1833815
1
  1. 1.5k
RESISTOR
0402
R3
Resistor
2072645
1
100pF
CAP
0603
C7
Capacitor
1344349
1
10k NTC
RESISTOR
0402
R7
Resistor
9528067
2
10uF
CAP
1206
C12, C13
Capacitor
2394272
1
1800pF
CAP
0603
C8
Capacitor
1865530
1
196
RESISTOR
0402
R1
Resistor
1802961
1
20k
RESISTOR
0402
R4
Resistor
2072753
2
22nF
CAP
0603
C1, C2
Capacitor
1301890
1
  1. 4.22k
RESISTOR
0402
R5
Resistor
2350371
1
47nF
CAP
0603
C9
Capacitor
2070428
1
  1. 66.5k
RESISTOR
0402
R6
Resistor
2073198
2
68nF
CAP
0603
C10, C11
Capacitor
1414650
1
75
RESISTOR
0402
R2
Resistor
2073246
1
AC Coil
LONGPADS
LONGPADS
JP1
2114372
1
BQ51013
BQ51013B
QFN-N20
U1
1
Vout
LONGPADS
LONGPADS
JP2
Header 2
4
0
RESISTOR
0402
R8, R9, R10, R12
Resistor
2072513
1
  1. 2.4k
RESISTOR
0402
R11
Resistor
1358052
The schematic:
And PCB layout:
Fullscreen contentimage_52589.html Download
<html><head><title>Jive SBS</title></head>
<body><font face="arial,helvetica,sans-serif">
<b>Error</b><br><font size="-1">
An general error occurred while processing your request.
</font></font></body></html>
As always: Comments and suggestions are welcome. Once I send the design to the fab it will be too late!
EDIT: I have updated the files. I have corrected some smaller issues I noticed while assembling the first units
WirelessReveiver_v0.2.zip
    mcb1 over 12 years ago in reply to janisalnis +1
    Janis I think the 1 year licence will have expired if you didn't collect it within a certain period. If the design is less than 4 layers, you could use the free version. Mark
  • janisalnis
    janisalnis over 12 years ago in reply to mcb1
    Thanks for help! I downloaded and installed newest Eagle freeware version and it opens your board and I can move the parts around. I will start checking it against the datasheet. It is nice that you made such a good starting point for others. I will modify the placement to fit in my project enclosure.
    Janis
  • janisalnis
    Thanks for designing receiver board.
    I downloaded the zip file. Schematic opens Ok.
    But when I click on the brd file it does not open and message comes:
    "Illegal data in file"
    May be I have too Eagle version
    Version 4.11 for Windows
    and should use the Farnell offer for 1 year free licence?
    mcb1 over 12 years ago in reply to waelect
    Hi Mike
    It's Mark
    Be sure to check his DRC and CAM file for the boards.
    The DRC will not tell you if the font is too small and for mine the 5mil was a little thin ... it printed okay but the wider was much better looking.
    When you run the CAM job (to turn the board into the various layers) be sure to watch for the warnings
    Just hit Yes
    I see he currently has a 5 day delay, but some problems if you ship via DHL.
    https://docs.google.com/document/d/1p6FH25ltGpzJQ5_8fbflDukqEKghiEcpuhJpngth2Is/edit?pli=1
    The other thing is the factory place a unique number on the board.
    This has been increased in size and on mine they cleverly placed it under the IC.
    If you're concerned Mitch offers this
    Q: Will my design get modified?
    A: A manufacturing code is added to the board to make sure the right board goes to the right person.  If for some reason you’d rather the numbers go on a particular layer (maybe you want to keep the code out of a certain area, or to have it put in a certain area), please tell me in your order email.  Note, it isn’t guaranteed, this information might be ignored.
    If you’d like to specify where to put the manufacturing code, here’s how to do it:
    • Include another layer in your .zip file, separate to the other layers.
    • Call this layer “mfgcode.gto” (for the code on the top) or “mfgcode.gbo” (for the code on the bottom).
    • Use your CAD package to add this text to that layer:  XxXxXxXxXxXx(That’s 12 Xs).  There should be nothing else in that layer.
    • Make the text at least 0.8mm (30mil) high, and use a stroke width (aperture size) for the text of at least 0.15mm (6mil).
    Which I thought was pretty good.
    Good luck
  • waelect
    waelect over 12 years ago in reply to mcb1
    Hi Mike, Suggestion on Hackvana will have a go. I have finalised a project with any CAD software so this will be a good challenge for me. Nice Job Eduardo.
