element14 presents
element14 presents
e14 presents blogs How To Build A 5V Buck Converter
  • Author Author: airbornesurfer
  • Date Created: 6 Jan 2021 4:33 AM Date Created
  • Views 3474 views
  • buck converter
  • project mego
  • step down dc-dc
  • dc to dc buck converter
airbornesurfer
airbornesurfer
6 Jan 2021
When you're building a project that has multiple modules with different voltage requirements, you may need to build a 5V buck converter. This video walks through the process to build a converter that will take up to 40V input down to 5V at up to 5A, and you can get the schematic as well as the necessary parts in the show notes below!
PARTS/TOOLS:
https://www.newark.com/tdk/slf10145t-220m1r9-pf/power-line-ind-22uh-1-9a-20/dp/90R0605
https://www.newark.com/nichicon/upw1c181med1td/aluminum-electrolytic-capacitor/dp/65R3976
https://www.newark.com/vishay/vs-6tq045s-m3/schottky-rectifier-45v-6a-to-263ab/dp/68AC5624
https://www.newark.com/vishay/k474z20y5vf5th5/ceramic-capacitor-0-47uf-50v-y5v/dp/27X7721
https://www.newark.com/vishay/d103z25z5vf63l6r/ceramic-capacitor-0-01uf-50v-z5v/dp/80K9840
https://www.newark.com/panasonic/eea-ga1h150/aluminum-electrolytic-capacitor/dp/83T6876
https://www.newark.com/texas-instruments/lm2678s-5-0-nopb/step-down-regulator-to-263-7/dp/41K4192
RESOURCES:
imagelm2678.pdf
5vbuck.fzz.zip
  • celcius1
    celcius1 over 5 years ago
    Excellent work Matt, but these buck converters are available off the shelf, pretty much the same design, Ill attach the link where I can get it in Australia, which is Altronics, and they do a lot of there purchasing from element14 https://www.altronics.com.au/p/z6334-dc-dc-buck-module-3-40v-input/
    So I hope this helps.
  • celcius1
