element14 presents
element14 presents
e14 presents blogs How To Build An Arduino Clock
  • Episodes
  • Author Author: airbornesurfer
  • Date Created: 15 Sep 2020 11:57 PM Date Created
  • Views 3530 views
  • clock
  • arduino uno
  • project colortyme
  • diy clock
airbornesurfer
airbornesurfer
15 Sep 2020
*****TITLE HERE*****
element14 presents  |  Matt Eargle's VCP Profile |  Project Videos
Clocks are a rite of passage for hardware hackers, and with this video you can start working on your DIY Clock merit badge using the Arduino platform to build a basic Arduino clock. This project builds on the Arduino Fortune Teller project and teaches programming concepts like timing and actively updating a display, so you can use it as a springboard for many more complicated projects!
PARTS/TOOLS:
https://www.newark.com/arduino/a000066/dev-board-atmega328-arduino-uno/dp/78T1601
https://www.newark.com/mikroelektronika/mikroe-55/display-board-lcd-2x16/dp/61W9875
https://www.newark.com/mcm/21-18938/breadboard-with-binding-posts630/dp/79X3923
https://www.newark.com/multicomp-pro/mccfr0w4j0221a50/carbon-film-resistor-220-ohm-250mw/dp/58K5029
https://www.newark.com/multicomp-pro/mccfr0w4j0103a50/carbon-film-resistor-10kohm-250mw/dp/58K5002
https://www.newark.com/adafruit/759/wire-gauge-28awg/dp/88W2571
https://www.newark.com/bourns/pdb181-k420k-103b/rotary-potentiometer-10kohm-17mm/dp/04B9684
https://www.newark.com/omron-electronic-components/b3f-4055-by-omz/switch-tactile-spst-no-50ma-though/dp/36K1872
THE CIRCUIT:
THE SKETCH:
//Projet ColorTyme
 //Phase 1: Simple LCD Clock
 //CC-BY-SA Matthew Eargle
 //AirborneSurfer.com
 //element14 Presents
#include "LiquidCrystal.h"
// Define LCD pins
 LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// initial Time display is 00:00:00 (24hr clock)
 int h=00;
 int m=00;
 int s=00;
// Time Set Buttons
 int button1;
 int button2;
 int hs=8;// pin 8 for Hours Setting
 int ms=9;// pin 9 for Minutes Setting
// Digital LCD Constrast setting
 int cs=6;// pin 5 for contrast PWM
 static int contrast=100;// default contrast
//Define current time as zero
 static uint32_t last_time, now = 0;
void setup()
 lcd.begin(16,2);
 pinMode(hs,INPUT_PULLUP);
 pinMode(ms,INPUT_PULLUP);
now=millis(); // read RTC initial value
 analogWrite(cs,contrast);
void loop()
 // Update LCD Display
 // Print TIME in Hour, Min, Sec
 lcd.setCursor(0,0);
 lcd.print("Time ");
 if(h<10)lcd.print("0");// always 2 digits
 lcd.print(h);
 lcd.print(":");
 if(m<10)lcd.print("0");
 lcd.print(m);
 lcd.print(":");
 if(s<10)lcd.print("0");
 lcd.print(s);
 lcd.setCursor(0,1);// for Line 2
 lcd.print("SURF STD TIME");
while ((now-last_time) < 1000 ) // wait1000ms
 now=millis();
last_time=now; // prepare for next loop
 s=s+1; //increment sec. counting
 /*-------Time setting-------*/
 button1=digitalRead(hs);
 if(button1==0)
 s=0;
 h=h+1;
button2=digitalRead(ms);
 if(button2==0){
 s=0;
 m=m+1;
analogWrite(cs,contrast); // update contrast
/* ---- manage seconds, minutes, hours am/pm overflow ----*/
 if(s==60){
 s=0;
 m=m+1;
 if(m==60)
 m=0;
 h=h+1;
 if (h==25)
 h=0;
    beacon_dave over 6 years ago +2
    airbornesurfer looks like you have a short circuit in the power rail in your schematic across pins 1 and 2 of the LCD display. Also pin 5 of the LCD display is floating in the schematic but wired to ground…
  • airbornesurfer
    airbornesurfer over 6 years ago in reply to beacon_dave +2
    Ah, good catch! Sometimes Fritzing makes/breaks connections like this behind my back Thanks for the heads-up; I'll have to go back and fix them when I get a minute!
    Also pin 5 of the LCD display is floating in the schematic but wired to ground in the breadboard layout.
  • airbornesurfer
    Ah, good catch! Sometimes Fritzing makes/breaks connections like this behind my back image
  • airbornesurfer
