element14 presents
element14 presents
e14 presents blogs Radio frequency
  • Episodes
  • Author Author: olivercohen
  • Date Created: 30 Jul 2019 6:57 AM Date Created
  • Views 1498 views
  • Comments 10 comments
Radio frequency
olivercohen
olivercohen
30 Jul 2019
I have a moving vehicle which I need to communicate with.
Radio frequency has its limits with distance.
My question is if I take an aerostat ballon to 400m high
Place a antenna attached to a tracker  To always send the waves to the vehicle.
Will that work?
Also how do I  tranmit to the aerostat antenna from the ground control 400m down ?
Any ideas?
    shabaz over 7 years ago in reply to olivercohen +3
    I don't believe that's practical in the way described over such distances to/from a moving vehicle with a whip antenna, using any known legal unlicensed spectrum. You can calculate it here, if you know…
    dougw over 7 years ago +3
    You could use something like LoRa to relay GPS location and send directions, but you would need to find some other way of sending video. As Shabaz suggested an LTE cellular link is about the only solution…
    shabaz over 7 years ago +2
    Hi Oliver, There's not enough information to answer fully (e.g. amount of information, and rate, and it's unclear if your communication needs to be bidirectional, and between which two locations - is the…
  • olivercohen
    olivercohen over 7 years ago
    VHF frequency
    I am looking for a distance of 100km
    I would like to transmit data video live streaming
    150kpbs
    from HQ to vehicle sending directions
    From Vehicle to HQ video streaming.
    You can calculate it here, if you know your receiver sensitivity for a good picture/reliable data stream:
    https://www.changpuak.ch/electronics/pathloss_rssi.php
    If you have some alternate antenna/tracking scheme that you think will work, then the antenna gain can be plugged into the calculator too.
    A workable option is cellular, if the locations are covered by such a network.
