element14 presents
element14 presents
e14 presents blogs Radio frequency
  • Episodes
  • Author Author: olivercohen
  • Date Created: 30 Jul 2019 6:57 AM Date Created
  • Views 1497 views
  • Comments 10 comments
Radio frequency
olivercohen
olivercohen
30 Jul 2019
I have a moving vehicle which I need to communicate with.
Radio frequency has its limits with distance.
My question is if I take an aerostat ballon to 400m high
Place a antenna attached to a tracker  To always send the waves to the vehicle.
Will that work?
Also how do I  tranmit to the aerostat antenna from the ground control 400m down ?
Any ideas?
    shabaz over 7 years ago in reply to olivercohen +3
    I don't believe that's practical in the way described over such distances to/from a moving vehicle with a whip antenna, using any known legal unlicensed spectrum. You can calculate it here, if you know…
    dougw over 7 years ago +3
    You could use something like LoRa to relay GPS location and send directions, but you would need to find some other way of sending video. As Shabaz suggested an LTE cellular link is about the only solution…
    shabaz over 7 years ago +2
    Hi Oliver, There's not enough information to answer fully (e.g. amount of information, and rate, and it's unclear if your communication needs to be bidirectional, and between which two locations - is the…
  • aswinvenu
    aswinvenu over 7 years ago in reply to dougw
    If considering LTE, Does wistron NeWeb LTE IoT Add-on Kit a potential solution? I never worked on this particular board.
    https://www.avnet.com/shop/us/products/avnet-engineering-services/aes-att-m14a2a-iot-add-g-3074457345635221606/
    avnet has already featured this board in the website.
    https://news.avnet.com/press-release/avnet/avnet-boosts-iot-starter-kit-portfolio-new-4g-lte-m-development-platform
    You could use something like LoRa to relay GPS location and send directions, but you would need to find some other way of sending video. As Shabaz suggested an LTE cellular link is about the only solution you could implement for a 100 km video link without enormous cost, complexity and licensing issues. If LTE is not always available you could use LoRa for the other data - you would still need a tall antenna (line of sight) for LoRa but at least if the video fails you can still have the ability to see location and send directions.
  • aswinvenu
    aswinvenu over 7 years ago in reply to shabaz
    Yeh I agree, I just checked the datasheet.  -123 dBm at 1.2 kbps.
    shabaz over 7 years ago in reply to aswinvenu
    Hi Aswin,
    I'm not sure that would work with CC1120 at that data rate to those distances, because they are using special coding at low bitrate to get the distances (and even if it was, it is not legal to transmit except in bursts (there is a duty cycle restriction, I cannot recall the specifics).
    You can calculate it here, if you know your receiver sensitivity for a good picture/reliable data stream:
    https://www.changpuak.ch/electronics/pathloss_rssi.php
    If you have some alternate antenna/tracking scheme that you think will work, then the antenna gain can be plugged into the calculator too.
    A workable option is cellular, if the locations are covered by such a network.
