element14's The Ben Heck Show
Blog Episode 134: Ben's Let's Try PCB Etching Episode
  • Author Author: pchan
  • Date Created: 23 May 2014 2:39 PM Date Created
  • Views 1574 views
  • Comments 8 comments
  • try
  • etching
  • ben's
  • let's
  • 134:
  • pcb
  • episode
  • tbhs_ep
pchan
pchan
23 May 2014
Ben Heck home page
All previous episodes
Ben's build kit
    I'm wondering how a transparency sheet like the ones used for the old overhead projectors would work instead of the glossy paper?
  • Problemchild
    Problemchild over 12 years ago in reply to e14 Contributor
    Probably melt on to the PCB I think.. If you managed to get a good transfer on to the OHP material you could just do the photo resist method like this:
    e14 Contributor over 12 years ago in reply to Problemchild
    you wouldn't place the iron directly on to the plastic, you would have to use a fabric layer in between the iron and the plastic.
  • Problemchild
    Only problem I see here is that when you print with a laser on to paper it's basically on the paper and here they choose glossy to enhance this effect, where with OHP material it will inevitably melt into the plastic a bit. The Laser printer rollers get damn hot that's why you had to get the proper  to stop it melting in the mechanism.
    If you get it hot enough to transfer I think you still have it hot enough for the OHP to melt.
    Either way if you have an OHP film you are better off with the optical method as this is much more accurate.
