element14's The Ben Heck Show
Blog My Gameboy Advance Sp Case Build
  • Author Author: xmxexrx
  • Date Created: 13 Aug 2014 9:51 PM Date Created
  • Views 1077 views
xmxexrx
xmxexrx
13 Aug 2014
After my Gameboy Advance Sp case broke while i was putting a new fuse in I thought it would be better if i just made my own.
So I made a design and made it from Plexiglas. I used a Dremel and metal files to bring it to size.
I Formed the sides from Plexiglas to with a candle.
I super glued the bottom to the sides than i filed it down to make it flush, then made the top stay on with some screws.
I made the buttons.
I made something to hold the tact switches for the buttons.
I cut the holes for the buttons and the screen.
I painted it white and blue and put it together. Not an expert painter nor do i like to wait for paint to dry. Put it together while some what sticky.
  • royston02
    royston02 over 12 years ago
    If you put a video for people to look and understand how to bend pexiglass and how to use a dremel to cut accurately, then it will indeed be of some use
  • xmxexrx
    xmxexrx over 11 years ago in reply to royston02
    This is my very first time doing something like this so i practice with small pieces of plexiglass to find how things worked when using different methods. I burnt lots of plexiglass doing this and for the dremel i just cut close to the line i made then file it down with a small fine metal file.
  • royston02
    royston02 over 11 years ago in reply to xmxexrx
    looking foward to a video.
  • royston02
