Ben Heck Featured Content
  • Ben Heck Featured Content
Forum This is a different kind of puzzle
  • Subscribers 42 subscribers
  • Views 375 views
  • Accessibility
could the Rasberry Pi ,or the Arduino base Boards could support a hard drive and,or a sata drive connection
    e14 Contributor over 10 years ago in reply to e14 Contributor +1
    As Clem has stated if you want to add a hard drive to the Pi you need to use usb powered external drive since there is no sata connector on the board. To adding memory there is two 512mb ram surface mounted…
  • clem57
    clem57 over 10 years ago
    Yes using Raspberry Pi. Use a external USB 2.0 connected hard drive.
    Clem
    yea but could you add more memory to it if you had to say like 320GB
    As Clem has stated if you want to add a hard drive to the Pi you need to use  usb powered external drive since there is no sata connector on the board. To adding memory there is two 512mb ram surface mounted to the board and not really easily exchanged.
