Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Repurpose old computer desk audio system
  • Subscribers 42 subscribers
  • Views 400 views
  • Portables
I'm sure you've gone through a couple external computer speakers over the years (I know I have), either from the electronics in them wearing out or from upgrades. I'm curious as to if you could find a way to repurpose them into a portable boombox and how you'd go about building an amplifier instead of buying a small one. I've built a few boomboxes myself using Lepai amplifiers and pelican cases for easier access to parts, but I'd like to see what your take on it might be.
I do have some criteria for it though: Parts have to be easily accessible/interchangable in case they're damaged, long battery life (8+ hours on heavy load), Aux needed, internal storage and bluetooth optional, and very durable and easily portable (i.e, carrying handle and small), and most importantly...it has to look cool with whatever flair you want to add, because the cool factor is everything.
I guess this is a challenge more than anything? Should be a fairly easy and quick build. I hope to see you build this and hope you enjoy building it as well. Take care, and I look forward to all future episodes
  • clem57
    clem57 over 10 years ago
    Codey Van Horne
         But for the battery that long you would expect real estate like a batter in a laptop which precludes  smallness (unless a boombox  which I do not consider small ok)image
    Clem
    e14 Contributor over 10 years ago in reply to clem57
    They do make some small 12v batteries and you can make a battery pack out of lithium ion batteries both in series (more volt) then parallel (more amps). I've done both and the only issue with them can be the weight.
