Ben Heck Featured Content
  • Ben Heck Featured Content
Forum what to do.
  • Replies 12 replies
  • Subscribers 44 subscribers
  • Views 1066 views
what to do.
bluidevil62
bluidevil62 over 11 years ago
I have a KEPCO FMP24-0.45K and I'm getting nowhere with KEMPO SO DO YOU HAVE A IDEA OR A WAY TO USE THIS POWER SUPPLY
    mcb1 over 11 years ago in reply to bluidevil62 +1
    bluidevil62 I was going to use it for a arduino project Apart from one Arduino board I know of, all others are 12v max input. This supply is 24v and I doubt the adjustment allows it down to 12v. You…
  • gadget.iom
    gadget.iom over 11 years ago in reply to bluidevil62 +1
    I cannot offer any advice based on the information you have provided. What I can do is refer you to my previous statement.
    What would you use it for? I wouldn't .... Just because you have something given/received or recovered doesn't mean you should find a purpose for it. I already gave advise about he safety issues regarding…
  • clem57
    clem57 over 11 years ago
    Does it look like this?
    It appears to put out 24 volts at .45 amps giving under 12 watts. A very low power high voltage DC. Someone like mcb1 might know a good usage.
    Cheers,
    Clem
  • bluidevil62
    bluidevil62 over 11 years ago in reply to clem57
    yes it does will this be the alternative to a transformer ac -dc
  • clem57
    clem57 over 11 years ago in reply to bluidevil62
    Most wall warts are 5V with 500 mA to 2.0 A. Your transformer would need a DC to DC converter which costs more than the previous wall warts.BTW, where did you get/buy this?
  • bluidevil62
    ebay
  • bluidevil62
    bluidevil62 over 11 years ago in reply to bluidevil62
    bluidevil62
    You'd need a regulator on the output ....BUT more importantly.
    This model is designed to be inside an enclosure as the mains connections are accessible.
    Personally I'd go fnd myself a 5v/9v or even 12v plug pack to SAFELY play with your arduino.
    Also for the future the Ben heck area isn't the only one on this website, there is arduino, power and a whole range.
    Unless clem had tagged me I wouldn;t have found the post and been able to advise you.
    clem57
  • bluidevil62
    bluidevil62 over 11 years ago in reply to mcb1
    could I use this as a battery charger for my metal detector
  • gadget.iom
    Based on the level of your knowledge gleaned from your posts I would recommend you take the advice given to you mcb1.
  • bluidevil62
    bluidevil62 over 11 years ago in reply to gadget.iom
    ok with my lack of experience could I use this as a power supply or charger for a metal detector
  • gadget.iom
