Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Arrow Finder
  • Replies 11 replies
  • Subscribers 45 subscribers
  • Views 1413 views
Arrow Finder
Hey, I was doing archery earlier and I shot an arrow into the woods by accident, This is not the first time I have done this. Would it be possibly to make some way to put a small insert into a carbon fiber arrow to make it trackable via radio, infrared, or even sound?
  • clem57
    clem57 over 11 years ago +1
    A long string?
  • clem57
    clem57 over 11 years ago in reply to e14 Contributor +1
    On a balanced arrow, center of gravity will be in the middle or the core. Outside would change the mass to one side. Clem
    jw0752 over 11 years ago in reply to e14 Contributor +1
    Hi Safeer, I am not sure there is a device as you describe with a power supply, and signaling means that would fit inside the shaft of an arrow without damaging the structural integrity of the arrow. The…
  • clem57
    A long string?
    Hi Michael,
    Even though an arrow is ancient technology it is extremely well engineered for the purpose for which it is intended. This level of engineering does not leave a lot of room for adding tracking or alert modifications. Almost certainly any modifications allowing tracking or alerting would ruin the balance and aerodynamics of the arrow. As with just about any change to a system there would be undesirable side effects. This does not stop us from dreaming however. Think about all the noise that a cricket can make with his hind legs. Perhaps one of the guide feathers could have some piezo crystal elements imbedded in it that would make a high pitched sound. Perhaps a thin layer of solar cell crystal could be put on the shaft of the arrow so that when hit by sun light the piezo crystals would be powered and give off the high pitched sound. However, even if it could be done without too much damage to the function of the arrow would you pay more for an arrow that you knew wasn't quite as good as a regular arrow but might be able to be found if lost? Thanks for the interesting question.
    e14 Contributor over 11 years ago in reply to jw0752
    not necessarily true
    if you were to add the tracker at the exact center of gravity of the arrow then no change would occur keeping in check that the carbon fiber is not deformed or there in no change in the aerofile of the stem
    this is quite easy to do take any old try car and take out its radio circuit. now at the motor outlet attach a small audio device
    and when you press the  radio controller the audio device will give noise so you can track it easily
  • clem57
    Clem
    Hi Safeer,
    I am not sure there is a device as you describe with a power supply, and signaling means that would fit inside the shaft of an arrow without damaging the structural integrity of the arrow. The axial center of gravity would be important as I suspect that the arrows are spun on this axis for stability. The longitudinal center of gravity would not be important as they routinely shift this center when they choose different points for the arrows. Any hollowing of the shaft would probably have bad consequences as the "g" forces when the arrow hits a hard target must be very high. Our signaling device would also have to withstand these "g"  force as well.  The funny thing is that the TV spy shows treat this kind of signaling and tracking technology as routine. I personally think they are pulling our legs.
  • william_hoffer
    william_hoffer over 11 years ago
    Yes I shoot Archery and yes I lost arrows (I use aluminum) but there is problems with putting a device inside the arrows called "Archers Paradox." When a arrows is released from the bow it flexes left and right. The more flexible the arrow and the weight of the pull of the bow the more flex the arrow has anything inside the arrow would either be broken by the flex or cause the arrow to shoot off the sighted path.
    Now with that said you probably could add a led and a small battery (such as a cheap and small watch battery) at the end in the nock (using a clear or only tinted nock) and then just use a slightly heavier point. But you will need a nock that can be unscrewed instead of one that is glued on and with carbon fibers I don't think any are like that.
    jw0752 over 11 years ago in reply to william_hoffer
    Hi Bill,
    I was hoping that someone with knowledge of the physics of archery would weigh in. I thought of another approach that would not involve structural modification of the arrow or electronics. If the arrows were dipped in a trackable scent we could just let Rover our trusty hound loose to go and fetch any arrows that have gone astray.
  • gadget.iom
    gadget.iom over 11 years ago
    To be honest, I'd be more worried about finding my arrow - buried in a hiker/walker.
  • william_hoffer
    william_hoffer over 11 years ago in reply to jw0752
    if going old school save your self time and a smell and during practice use a ribbon tied around the shaft and sits on the out side fletch area. I used this mod when I use to shoot 3D archery. During hunting I never loose arrows, just tips buried in a tree.
    Target Practice then use the snell trick.
  • william_hoffer
    william_hoffer over 11 years ago in reply to gadget.iom
    Paul, if you are shooting people, you should not be out hunting
