Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Using a laptop optical drive slot to house a dedicated RasPi sub-processor
  • Replies 13 replies
  • Subscribers 44 subscribers
  • Views 1324 views
  • Single Board Computer
cruz53
cruz53 over 11 years ago
Hi Ben,
     I use my Raspberry Pi via my laptop quite frequently for software development and it is always awkward having to connect to it externally via serial or a crossover cable. I also have a CDROM that goes entirely unused. I was thinking it would be awesome to make a raspberry pi case that could fit inside that CDROM slot and be wired internally. Ultimately the perfect install would be one where the Enet ports of both the laptop and the RasPi are free and the RasPi I/O is still accessible. (possibly it could be pulled out in the same fashion as the CDROM?)
Thanks Ben I know it's possible, please show me the way!
Jim
  • kidiccurus
    kidiccurus over 11 years ago
    You would probably have to open the laptop up and rewire or even replace the connector to have the pi connect to your laptop in a usable way. Moving the ports and io is not to hard, but the risk!to your laptop is probably to!extreme for this to be worth attempting.
  • clem57
    clem57 over 11 years ago in reply to kidiccurus
    Ventilation is an issue here as well. kidiccurus is right with the added ptoblem that laptops are alrady crammed to the gills will little room left over. Why not try a desktop as a better first attempt where more room exists learning much., and then later use the Pi compute module for small enclosure or laptop.
    Clem
  • cruz53
    cruz53 over 11 years ago in reply to kidiccurus
    Could be powered off a 1:1 isolation transformer or similar
  • cruz53
    cruz53 over 11 years ago in reply to clem57
    And clem because the whole point is to basically have a hardware virtual machine always running and totally isolated
  • clem57
    clem57 over 11 years ago in reply to cruz53
    Trying to point out this: experiment with a desktop to learn with goal for laptop. Climb the mount and not jump to peak. Just my experience learned with software mainly. EOS
  • cruz53
    Sorry i meant to say that the portability was the whole point. And the main issue is that you would want to use SSH to connect yet keep the existing enet ports free on both devices
  • william_hoffer
    william_hoffer over 11 years ago
    most laptops don't have that much space where the optical drive is to put a Raspberry Pi there. As Clem Martins suggested maybe use the Pi compute, I repair computers and usually the optical drive on a laptop is usually a slim line version and keeping the Ethernet and full size usb's would not fit. take the Ethernet and full size usbs off then you will need to beef up the cooling for the Pi. One thing is powering the pi might be a problem, You need 5 Volt Micro-USB power supply with at least 1.8 Amp output none of the laptops usbs provide that much power. They provide 2.5 volts. so you will need a power cord coming out.
    Now after all that modding, testing, fixing found problems, testing again and there is still a good chance this wouldn't work, how is that easier than just putting the pi in a case and set it beside the laptop?
  • cruz53
    cruz53 over 11 years ago in reply to william_hoffer
    Wow you guys sure are negative.  My laptop is a full size 17inch with 32bit arch. And several legacy ports I use for plc programing. Im certainly not talking about doing this in a macbook air lol
  • cruz53
    cruz53 over 11 years ago in reply to cruz53
    Also the 1.8 amp is clearly to supply the pi's own usb loads so of course there would be some restrictions there
  • cruz53
    Also also of course there are easier ways to do it.  How many of the ben heck episodes do something that takes several days of work when there is an obvious easier way.  (Which usually involves not taking some game console apart to begin with lol)
