Ben Heck Featured Content
  • Ben Heck Featured Content
Forum A portable cooling device on your wrist.
  • Subscribers 44 subscribers
  • Views 779 views
  • Wearables
txrlmlerke
txrlmlerke over 11 years ago
Hi Ben
I been trying to power a peltier cooler to wear on your wrist to cool the body down. it needs to be small like a in wrist sweet band.. the problem I have designing it is the power. my question is can a peltier be power with a 3 v coin battery and made rechargeable? or you can make it on your show.
  • kidiccurus
    kidiccurus over 11 years ago
    Coin cells are pretty useful when a decent amount of power is needed, as is the case here. Your best bet is a recharable li-po or li-ion battery and charge circuit. Be careful with the charge circuit as it can be very dangerous if it malfunctions.
    michaelkellett over 11 years ago
    This isn't going to work very well !
    The amount of heat power a peltier device can pump depends on many things but they include the temperature differential between it's two faces and the electrical power input. Unless you have a fan or a big heatsink on the hot side of the peltier it won't be able to get heat away any better than your skin can. In fact, since you will need to put power in, unless you are careful all that happen is that the whole thing gets hot, but with one side a bit hotter than the other.
    A decent sized device will require many watts of input power so batteries are not going to be  a viable power source.
    You will do MUCH better with a wet wristband and a fan (and no peltier).
    balearicdynamics over 11 years ago in reply to michaelkellett
    Michael, a stilling suit from Arrakis may work better image
    Enrico
  • fvan
    fvan over 11 years ago
    Have you seen this ?
    michaelkellett over 11 years ago in reply to fvan
    Amazing - you would definitely be better off with just the fan - except possibly if the air temperature was above 37C. I think the fan blowing on wet skin (sweat will do) will beat the peltier up to much higher temperatures.
    It is actually very difficult to measure the cooling effect on a human of this thing or a direct fan so comparing them will be subjective - I look forward to hearing about the OP's results.
    @ Robert - note the size of battery in the video.
