Ben Heck Featured Content
  • Ben Heck Featured Content
Forum TBHS episode suggestion: Removing the Pi boot text/logo and replacing it with a splash screen.
  • Subscribers 43 subscribers
  • Views 526 views
  • Single Board Computer
  • felix
  • customization
  • the ben heck show
  • raspberry pi
  • software
  • linux
f5kn
f5kn over 10 years ago
I believe most people that make a project using whichever version of the Pi they want don't want to see all of that text nor the Pi logo on the screen every time their device boots up. So how could we disable all of that and put a nice splash screen in its place?
Could Felix teach us how to do that?
Thanks!
  • laurens-wuyts
    laurens-wuyts over 10 years ago +1
    The Raspberry pi has no real BIOS. Everything is located on the SD card, so you can't really mess up. If you do mess up, just format the SD card and start again. As for the splashscreen, it's possible…
  • william_hoffer
    william_hoffer over 10 years ago
    to do it would mean changing things in the Bios of the Pi and I am not sure its possible. If possible then you are now messing with the Bios and that is never a good idea. One wrong line of code and you brick the Computer and it is unusable.
  • f5kn
    f5kn over 10 years ago in reply to william_hoffer
    Apparently that would be simpler than I initially thought, at least according to: https://www.pi-supply.com/make/disabling-verbose-boot-mode-raspberry-pi/
    Although it would just remove the logo.
  • laurens-wuyts
    The Raspberry pi has no real BIOS. Everything is located on the SD card, so you can't really mess up. image
    As for the splashscreen, it's possible to do, but it will show some text before it loads the splashscreen.
    I even put a video to play instead of a static image.
    The text is show as long as the  right components aren't loaded to display the image/video.
    You can only fully remove the text when you compile your own kernel.
    And I think that's a little above the scope of the show.
    Laurens
  • william_hoffer
    william_hoffer over 10 years ago in reply to laurens-wuyts
    after a few inquires yes the splash screen is on the sd card but you are wrong about it not really having a bios. it has a simple Bios since with out a bios the system would not have the instructions to look for the sd/micro sd card and where on the sd/micro sd card to find the exc files to start up your OS. To compiling a kernel, I don't know about Ben or Karen but I think Felix might be able to.
  • laurens-wuyts
    laurens-wuyts over 10 years ago in reply to william_hoffer
    Well, that's true, but no one changes the bios, as it's not needed.
    I'm pretty sure Felix is able to compile a kernel, but I don't think the viewers can and it's a little to advanced for them.
    Laurens
