Ben Heck Featured Content
  • Ben Heck Featured Content
Forum How to modify a set top DVD/Blu Ray player for 12V operation
  • Replies 9 replies
  • Subscribers 45 subscribers
  • Views 1370 views
  • Portables
jaevans
jaevans over 10 years ago
That should say it all.
  • clem57
    clem57 over 10 years ago +2
    Do you have a schematic or datasheet for your DVD? Clem
  • william_hoffer
    william_hoffer over 10 years ago +1
    no it isn't, there are the questions like, why? I can buy a car dvd player with double screens for 89 dollars or 39 dollars for a dvd player and tv. So why try to convert a regulars dvd player to a vehicle…
    jw0752 over 10 years ago in reply to jaevans +1
    From what I can see this is a quite simple SMPS and only has a single voltage output of 12 volts. If there is further voltage conversion being done it is on the other boards and probably as needed to power…
  • william_hoffer
    no it isn't, there are the questions like, why? I can buy a car dvd player with double screens for 89 dollars or 39 dollars for a dvd player and tv. So why try to convert a regulars dvd player to a vehicle dvd player then add in the price of the of a screen. It would seem just cheaper to buy one with the screen.
  • jaevans
    jaevans over 10 years ago in reply to william_hoffer
    You've made too many assumptions, forgetting the main point being that this is my project and I have my reasons that I don't need to explain to anybody else.  Who says I am going to use this in a vehicle?  Who says I don't already have a display?  Anyway, I can see I will get nothing but ridicule here for suggesting a Ben Heck project.
    I like to use what I already have rather than buy something new.  I believe in reuse and conservation.  I believe in the journey rather than the destination.  I enjoy working with my brain and my hands.  Enough said.
  • william_hoffer
    william_hoffer over 10 years ago in reply to jaevans
        Yes your Project, a project where you made no simple attempt to explain anything but stating the project you want Ben to do. As I said you did not explain why this is a good idea, did not say anything to make any one have a reason to get excited by your idea. You took more intrest in trying to make your self the victim and that none of us " use our brains and hands" to make things.
        To enjoying the journey and not the destination, what journey your destination was "Build my idea" with no explaintion to lead us on the journey.
         To ridicule is a matter of perspectives. You want to see miss treatment check out the threrad "metered toilet paper" the arthur had a reason to be upset. Still not sure where I ridicule you, I did think your prenstation was lacking and I was hoping you would take up the challenge to explain it but know you just want to be offened and to lash out.
       Now to you responding I don't give a flying fig if you do or don't thats your choice. You acted childish in your reponse when I just posted a question on "why this is a good idea."
    Bill
  • clem57
    Clem
  • jaevans
    jaevans over 10 years ago in reply to clem57
    No schematic but I do have photos of the power supply board, both sides, so I can reverse engineer the schematic.  It may be simpler for me to just measure strategic test points on the board, remove AC, and then inject 12V where the supply provides that and see if I get a functioning unit.  The power supply not only provides +12V, but also Vcc (probably 5V or 3.3V) for the main circuit board as well as 5V for a USB connection and pass through for the power and eject buttons, LED, and IR sensor.
    Pins to the main board are labeled +12V, GND, IROUT, Vcc, GND, USBP, USBM, USB_Vcc, VSTB, VSCK, LED, and GND, so these should help a lot, too.
    I'm not a blu-ray expert but suspect this is about as simple as a power supply could get for these devices.
    Oh, and schematics seem to be available out there for a fee.
    Hi John,
    Post the pictures that you have for the board. Hopefully the power supply board is separate and not integrated with the main board.  From what you describe the power supply is probably a switch mode power supply (SMPS). If it is a SMPS just injecting 12 volts where it presently is will not generate the other voltages that you may need. They will likely come from unique taps on the high frequency transformer. Once you identify what is needed for voltages, most likely, you will have to use separate DC to DC converters to get to the other voltages. There are small DC to DC variable voltage converters low cost converters available from e-bay that could be used. If you are able to purchase that schematic that you mentioned it might eliminate some of the guess work.
    John W.
  • jaevans
    jaevans over 10 years ago in reply to jw0752
    I didn't want to turn this into a problem solving session as I'd like to enjoy the work myself - I just started it out as a suggestion for the show (though I am convinced it really is quite trivial for that).  Anyway, here are the pix, grabbed from an ebay auction of the same model board as I've not removed my board yet. - john
    From what I can see this is a quite simple SMPS and only has a single voltage output of 12 volts. If there is further voltage conversion being done it is on the other boards and probably as needed to power logic. I would be surprised if this board is capable of much over 2 amps at 12 volts. It will be fun to follow your progress as you do your project so please post some more pictures and details of how it turns out.
  • sunny94
    sunny94 over 9 years ago
    They are DVD systems that haven't been made with a GPS navigation system. Two groups can be found: The Gps navigation and also the no- GPS car DVD. They however produce other features the happen to be made with Bluetooth support.  This selection enables you to hear music and you may also receive calls.  The machine also has a radio and   music player. If you're searching for any more complex system, then your GPS DVD player may be the best brand out there.  It's been made with a GPS navigation feature along with a map.  Additionally, it arrives with a Bluetooth, radio receiver, stereo, and subwoofer, 3G Internet along with a USB and SD input.
    The motto of EinCar is Expert In Car electronics. Also, Eincar sells only top quality stuffs with global standards. Every EinCar’s goods are always reviewed by our experienced Qc team with proffessional rules. Under its strict tests and qc procedure, it's worldwide standards both in quality and safety.
    If you wish to reverse your vehicle from a automobile parking space, the thought of using of the car backup camera is a terrific way to make certain that you don't mistakenly hit anything. If you are using the interior mirror, they're most occasions not efficient particularly if you drive a truck or perhaps an Sports utility vehicle. These units are often available on greater finish models as well as, it is simple to have them in a retail store at significant prices. These cameras work by mounting to the back of the vehicle either around the license plate or around the rear bumper.
    Whenever a Bluetooth is met having a Bluetooth stereo, they've created an interaction around a network that is not just like a large one the thing is for Wireless and computers. Typically, it’s known as an individual area network and may hold a maximum of eight devices. Every one of these devices has one central hub (within this situation, the car stereo), and may pass information and data between one another to effectively use Bluetooth.
    Of car audio updates, this is often likely probably the most economical. Jacks are usually existing in nearly all car stereo systems-there's accessible, but generally, they are not used to their finest possible. Some vehicle proprietors disregard the truth these jacks may be used to produce audio or appear by utilizing outdoors sources just like a Personal stereo, an digital audio player, an I-pod, etc.
