Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Turning wireless trackball mouse into a wired one
  • Subscribers 42 subscribers
  • Views 522 views
  • Controllers
b4blue
b4blue over 11 years ago
I have no need for wireless feature of the trackball mouse, there is no movement so I don't really mind the cable, plus the batteries are a constant problem. How could I change it into a wired one.
    e14 Contributor over 11 years ago +1
    If all you're looking to do is get rid of the dependence on batteries, you could run a USB cable to the track ball and use the power from that instead of the batteries. You'll likely need a regulator to…
    shabaz over 11 years ago
    That could be (practically) near-impossible due to high level of integration inside the mouse. I don't think there is any usable USB interface inside there that you could connect to.
    If all you're looking to do is get rid of the dependence on batteries, you could run a USB cable to the track ball and use the power from that instead of the batteries.  You'll likely need a regulator to get the right voltage, and you'll still need the wireless connection for the mouse functions, but it seems like this could be accomplished with relative ease.
    Good luck!
  • b4blue
    b4blue over 11 years ago in reply to e14 Contributor
    This is a great answer. Its not what I hoped for, cause there is still a bulky device that connects to USB (see picture), but at least I can get rid of the batteries. Thank you!
    e14 Contributor over 11 years ago in reply to b4blue
    You might be able to cram the guts of your receiver into your track ball housing.
