Ben Heck Featured Content
  • Ben Heck Featured Content
Forum My dream device made real
  • Subscribers 42 subscribers
  • Views 534 views
I would love to see a small system like a raspberry pi or similar fitted into a Psion 5mx case. with either same screen or a colour screen fitted, network capabilities and original Psion keyboard. Running from the same battery pack would also be great or fitted with a new one.
  • toxxn
    toxxn over 10 years ago
    This would be a neat little way to turn the Raspberry Pi into a Handheld Portable Pi Laptop. With the size of the Psion 5mx, I don't think there would be a problem fitting a Pi into the case, might have to remove some things, but possible. I would assume that the driver components for the 5mx's lcd are on board, meaning that an external LCD roughly the same size as the original LCD with a separate driver board would need to be used and then fit to the case. I believe the hardest part of a project as such would be incorporating the original keyboard to work with the Pi, unless it has some sort of port to connect the keyboard to an external source.
  • 1234jgs
    1234jgs over 10 years ago
    If you go into the main element14's The Ben Heck Show section under "Help Ben Solve Problems" there is a button titled "Let us know," if you push that you can make that suggestion.
