Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Build suggestion: A pool table converted to a CNC Router
  • Replies 9 replies
  • Subscribers 43 subscribers
  • Views 1303 views
  • Mechanical
yotosama
yotosama over 8 years ago
I don't know if that has been done already, or if it's even possible. I would however be interested to see it. Thank you.
  • gam3t3ch
    gam3t3ch over 8 years ago +1
    Well if you guy the table use the frame its possible even to make a 3d printed machine to do the trick on that give a 6-8 inch drop would beef up the side rails for x and y just seems like too much wasted…
  • yotosama
    yotosama over 8 years ago in reply to gam3t3ch +1
    I operate a Anderson Stratus Pro economy CNC at my job, and really like the idea of having a Cnc in my shop. Just kind of at a loss where to begin. The image is of the machine I run and repair when I need…
  • gam3t3ch
    Well if you guy the table use the frame its possible even to make a 3d printed machine to do the trick on that give a 6-8 inch drop would beef up the side rails for x and y just seems like too much wasted materials along the side of it tho. here is mine on a  old work bench actual cutting area is 2ft x 4ft but machine is bigger.  Second picture is of my original build tho much smaller.  For a pool table however incorporating a vacuum bed for dust and suction would be cool Maybe even some tool storage or a raspberry pi controlling it with a built in touch panel for cnc control since universal gcode sender works great on the pi wouldn't be a issue would be a cool idea if you had the space.  I would probably do something like that with a laser cutter tho for fun if I had a pool table kicking around. lol
  • yotosama
    I'm holding a cougar coin fed pool table for a family member in my shop,
    they never got a place big enough for it. I've tried selling it and giving
    it away no luck. I was just thinking maybe I can convert it to something
    that's actually useful.
  • gam3t3ch
    gam3t3ch over 8 years ago in reply to yotosama
    Nice!, that would be a fun project.   Certainly doable that's for sure.
  • yotosama
    I operate a Anderson Stratus Pro economy  CNC at my job, and really like the idea of having a Cnc in my shop. Just kind of at a loss where to begin. The image is of the machine I run and repair when I need to.
  • yotosama
    I kind of like both the rigs you built. As a router for my shop I don't need a hulking beast, just something serviceable and useful for smaller projects at home or for friends.
  • yotosama
    I admit, your ideas for it are sounding way more awesome than my original thoughts on the subject.
  • yotosama
    yotosama over 8 years ago in reply to yotosama
    I imagine in able to get a vac system involved on the table would need me to remove the slate top. Or I was thinking of leaving the slate intact and using tubing hooked to the pockets as a means of suction for a spoil-board.
  • yotosama
    This is the style of Table I have.
  • cameron36816718.
    cameron36816718. over 8 years ago
    I don't think this would be a good idea imo however I would love to see a third console added to that colecovision/sega that you did ages ago. you did say you will probably add a third at a later date. :-)
