Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Mini steam electric generator for a NYC apartment
  • Replies 12 replies
  • Subscribers 45 subscribers
  • Views 1693 views
  • Mechanical
maestr0pl
maestr0pl over 10 years ago
I've recently moved in to a small expensive apartment in Manhattan. My rent covers gas and water but not electricity. I want to save some money. I was thinking about building a small steam electric generator I could use on a gas stove. It's all about money efficiency, gas and water is free!
I'd like Ben to build an electric generator powered by a steam from a boiling water on a typical gas stove. Would that generator be powerful enough to charge my phone or maybe even it could light on a regular 110V bulb?
EDIT:
It is absolutely obvious that such an idea is nothing but a waste of resources. The only reason to build a steam generator is that it can be built!
If the ideas posted in this section are supposed to be more serious, let me rephrase mine:
Imagine, you are camping deep in the woods of Alaska. It's a cold night and your phone battery is about to die and you need a phone GPS to find a way back home. The situation seems to be very bad, but you know that you are safe because you have an awesome steam powered mobile charger. You boil water from a melted snow in a pot on a fire. You put a special lid on the pot. Steam from the boiling water powers a mini electric generator. The phone gets charged. Your life is saved.
Message was edited by: Pawel Raszewski
    shabaz over 10 years ago +2
    Many people in the UK have un-metered water supplies too (this is changing) however I don't know of anyone who would waste a tap water resource to generate electricity. If anything we should be asking…
  • william_hoffer
    william_hoffer over 10 years ago +2
    as said its not money wise because someone is paying for water and heat and they will notice they are being charged for a excessive amount of water and natural gas and I would wager that very soon that…
    mcb1 over 10 years ago in reply to shabaz +2
    Agreed. There is nothing like wasting one resource for some dubious purpose. In NZ we did it with our natural gas and turned it into Petrol, with huge inefficiency. Good quality drinking water is a precious…
    jw0752 over 10 years ago
    Hi Pawel
    The cost to build such a device and make it safe would cost more than years of electricity especially if you are only talking about enough to charge a phone or run a small light. You might be better off looking at a solar cell and battery if your apartment has access to sun light. The side effects of a boiler on the stove would be excess humidity in your apartment from the burning gas, (when gas burns it produces water),and from the exhaust steam of the steam engine. There would also be excess heat in your apartment, and danger from the pressure inside the boiler.Strictly from a monetary standpoint I would use the electricity provided and be conservative by using efficient light bulbs and unplugging appliances and chargers when not in use. I am not from the Ben Heck show so they may still weigh in on your question.
  • maestr0pl
    maestr0pl over 10 years ago in reply to jw0752
    Hi John,
    I'm totally aware that such a device doesn't make sense from the economic point of view. I'd like to get it built because "it can be built", it may work, it solves the problem of free electricity in a ridiculous way (free water and gas in this case).
    I was also thinking about a different type of electric generator which would be powered by a running water from a faucet. Imagine this, it's dark in your bathroom and to turn a light on you have open a faucet with a generator connected with some LEDs.
    I think those ideas fit well the concept of the show.
    Pawel
    jw0752 over 10 years ago in reply to maestr0pl
    OK Sounds good.
    If anything we should be asking the water corporations worldwide what they're doing to fix the typical 30% of water they are wasting every day due to leaking pipes. An alternative idea would be a water leak detector for the show. The good designs are non-trivial so would be interesting to see.
  • william_hoffer
    as said its not money wise because someone is paying for water and heat and they will notice they are being charged for a excessive amount of water and natural gas and I would wager that very soon that when people's leases come up for renewal the water and heat will not be paid for buy the landlord  but by the renters. Think how unhappy your neighbors will be when that happenes. Plus on the green side you will be wasting more water and natural gas.  Total cost for this build is around 160 dollars with zero emissions S.P.R.E.E. (Solar Photovoltaic Renewable Electron Encapsulator), a Compact, Durable, and Portable Solar Energy Generator
    Agreed.
    Good quality drinking water is a precious resource, and in most cities the infrastructure to support this is enormous.
    It seems that New York supplies 1.2 billion gallons per day, and might not be that keen to have someone develop a hydro system based on their water.
    https://en.wikipedia.org/wiki/New_York_City_water_supply_system
    While I applaud your interest in reducing the power bill, you might want to investigate what is using the power and work on that.
    Lighting (or poor lighting) choices can make a large difference, and LED's or even more focused task lighting can reduce the consumption dramatically while improving the light level.
    The choice of colour scheme can also have a dramatic effect on the light levels.
    A choice of solar with storage and maybe a small bicycle powered generator that charges a storage battery may cover much of your daily needs.
    With any alternative system there is an upfront cost, the running cost and the on-going maintenance that need to be factored into the equation.
    In most cases it works out more than the supplier cost, especially in a large city.
  • maestr0pl
    maestr0pl over 10 years ago in reply to mcb1
    I updated the first post with the description because I notice that some of you didn't get the idea right. You keep telling me the obvious things that this idea is a waste of resources. Yes, I know it image but it is not about saving resources or saving money on an electric bill, it's about building something cool. I should have been more clear from the beginning. Sorry. I added an alternative use case for the steam electric generator. Is that any better?
    Hi Pawel,
    I loved your story. It does add a new dimension to the discussion. I am not an expert on steam engines but I did have a small one when I was younger. It had a boiler powered by solid fuel pellets and ran a small piston engine and a flywheel. The amount of pressure generated by a household pressure cooker would suffice to make it go and it could perhaps turn a small electric generator so as to produce a couple of watts of electricity. You could in fact recharge a cell phone with this over several hours. If I were to want more power than this in the wilderness I would have to bring my wife to help me carry the heavier boiler and larger steam engine and generator, though I doubt that I could get her to chop the wood. As long as you aren't talking practical sources of energy you can have a lot of fun playing with these ideas. I do believe that a proper generator a fixed to a faucet would also light an LED. Just some side information many dentists are now using drills that have a small internal turbine or magneto that produces enough electricity to power an LED headlight on the drill so they can better see what they are drilling in your mouth. Pretty cool!
  • william_hoffer
    william_hoffer over 10 years ago in reply to maestr0pl
    this is still dangerous, you need to keep water in the boiler or BOOM!!!!. see why its very impractical and dangerous? That's why we are so against the idea.
    Hi Pawel,
    william_hoffer
    Is 100% correct and I should not have made light of the danger involved. There is a lot of energy in any boiler under pressure. When the pressure containment is lost the temperature of the water immediately turns it to steam which can cause extreme burns. It is best to probably keep this type of build in the thought experiment realm. Even if you can do it safely perhaps some other person who follows you may not be so lucky.
