Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Raspberry pi zero audio system
  • Subscribers 42 subscribers
  • Views 616 views
  • Single Board Computer
kerbingamer376
kerbingamer376 over 10 years ago
my idea is to use the new raspberry pi zero to make a home audio streaming system, like multi-room music streaming. I think the zero would be good as it is very small (smaller than an arduino) and has the 1Ghz processor of the pi 2, making it so fast!
  • makerkaren
    makerkaren over 10 years ago
    What kind of functionality would you want it to have? Would it just be a way to connect one music playing device to multiple speaker systems in various rooms? How you like the controls to work?
    I just wanted to clarify that the Pi Zero does not have the same processor as the Pi 2.
    It has a BCM2835, the same as a Pi 1, the Pi 2 has a BCM2836.
    Saying that the Pi 1 is clocked at 700 MHz by default, whereas the Zero is clocked at 1 GHz, so it is significantly more powerful. I've heard of people making audio systems with the normal Pi 1, so the Zero should still be plenty powerful enough for the task. It just wont be comparable to the Pi 2, they have the same clock speed, but the Pi 2 is quad core vs. Zero's single core. Additionally the Pi 2 uses a whole different architecture, ARMV7, vs ARM11, so it is basically better in every regard.
    Sounds like a really cool project though, I've thought a few times about something similar, using maybe a network of Arduinos to tell who is in which room and sending the info back to the Pi so it can chose where the audio goes.
    This might not be what you had in mind, but it might give you some ideas.  This is a DLNA end-point. I'm using BubbleUPnP on my Android phone to tell it to get my music from my music server. I used this as a guideline and used a Raspberry PI 1 B+. I also used a HiFiBerry Amp+. I'm also very curious about this  amp possible working or if something is coming down the line that could.
    http://blog.scphillips.com/posts/2014/05/playing-music-on-a-raspberry-pi-using-upnp-and-dlna-v3/
