Ben Heck Featured Content
  • Ben Heck Featured Content
Forum Wearable Air Cast with Digital Scale for weight bearing measurement
  • Replies 7 replies
  • Subscribers 45 subscribers
  • Views 1428 views
  • Wearables
headsup
headsup over 10 years ago
Hey Ben,  Love your show!  I broke my leg in three places... attached are some fancy photos of a medical steel rod and small metal plate.  I wore an aircast (plaster is so 1980's) [fibreglass is sooo 1990's]...and eventually healed up pretty good... but during the difficult 'weight bearing' period I had a difficult time one-footing it onto a scale to see how much weight I could bear on my weak, pathetic, scaredy cat, broken leg...
I am not a great Maker (yet) but I did envision an air cast boot coupled with a digital or analog scale that would be used all over the world to help rehabilitate the wounded.  I enlisted a young maker in the making and he uncobbled a couple of digital scales I grabbed at Goodwill -
And that is where we made it with our project - Please consider helping.  A Maker in Guelph, Ontario, Canada.
  • makerkaren
    makerkaren over 10 years ago +1
    I don't think I fully understand what you are looking for or maybe I just don't understand the problem in the first place. What exactly are you trying to measure and what exactly was the problem with using…
    e14 Contributor over 10 years ago +1
    Digital scales usually use load cells for measuring weight. Here is a good instructable for understanding how you could take apart an existing scale and then try and attach it to an air cast. Arduino Load…
  • makerkaren
    I don't think I fully understand what you are looking for or maybe I just don't understand the problem in the first place. What exactly are you trying to measure and what exactly was the problem with using a typical bathroom scale? Do you need some sort of scale placed in the bottom of the air cast boot that would have a readout somewhere?
    The idea sounds intriguing.
  • headsup
    headsup over 10 years ago in reply to makerkaren
    Hi, thanks for replying!
    The problem with a broken leg is partially feeling very fragile and possibly fearful of putting too much weight on your leg. First stage is "non weight bearing" then you move to "partial weight bearing" and this is the phase that would benefit (or "Ben"efit) from a display right on the air cast.  The display could easily tell you what percentage of weight you are applying or in pounds or kilos. Thanks Team. Ask for more details if needed.
  • headsup
    Thanks Karen!
    Arduino Load Cell / Scale
    If you want a very small profile scale you could look into pressure sensitive fabrics: Here is a video https://www.youtube.com/watch?v=qUHcwWi0Q-k
  • headsup
    headsup over 10 years ago in reply to e14 Contributor
    Thank you very much James - Solid info you have given me.
  • marieloson
    marieloson over 9 years ago
    Hi, if just the digital weight scale, i recommend the etekcity brand which easy to use and accurate.
  • ninjatrent
    ninjatrent over 9 years ago
    Good idea Paul Clarke. I know the pain of a broken leg as well. We often don't realize how important a component is until it breaks. My fibula and ankle are permanent residence of a  titanium plate and mounting hardware. It was a very unpleasant healing process. I am sure any technology that y you help to develop in regards to this matter will be greatly appreciated by the people of the world. You don't always have to be a medical professional to realize an idea that could benefit the future of medical technology. Doctors usually go to an engineer when a medical technology needs to be created. The engineer, the mad scientist, and the dreamers build tomorrow.
