Ben Heck Featured Content
  • Ben Heck Featured Content
Documents See Ben Heck's Raspberry Pi Build Episode -- Episode 45
  • Author Author: joeman
  • Date Created: 6 Jul 2012 2:24 PM Date Created
  • Last Updated Last Updated: 4 May 2012 7:24 AM
  • Views 4685 views
  • Likes 8 likes
  • Comments 17 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
You have been asking for it, so we're finally bringing it to you! A retro computer for only about $35? Watch Ben build a retro-styled computer using the Raspberry Pi!
Click Here for access to all the supporting files you will need to replicate this build!
Check out more Raspberry Pi Projects in Ben Heck's Raspberry Pi Builds!
  • mod
  • raspberry
  • pi
  • mods
  • build
  • heck's
  • giveaway
  • episode
  • build_challenge
  • raspberry_pi
  • rpiexpert
  • ben
  • show_idea
  • german
  • tbhs_ep
  • hbarrett
    hbarrett over 14 years ago
    What is the make and model of the usb hub being used?
    e14 Contributor over 13 years ago in reply to hbarrett
    Majority are about the same.. (note I said, Majority.. yes, there are some bad apples out there..) I have one with the Dynex label (sold by Best Buy electronics) that outputs to 7 total, and has a similar 5.0V 1000mA (1-Amp) wall wart.  I just cracked it open, and plan on hard-soldering the wires from the Mini-B power connector to the +5V plug on the USB hub, so all 7 ports will be free.  It has a older style mini-B (the |] type, not the |)  ) that feeds the hub from a source. regular A.
    The one Ben used, (correct me if I'm wrong) looked like a 4-port version I've seen under the (GE) Label.  (Yes General Electric).. though it may've been cloned, and sold under another label.  I had one before, bought from a clearing house store (Big Lots, they buy overstock, and sell at discount.).. but it didn't last very long.. fried all 4 port fuses with 4 USB-to-IDE/SATA drive dongles... (yes, I'm brutal.)  It also had a 1-Amp supply with a barrel connector (roughly same diameter as a mini stereo plug.) for power.  (seemed pretty generic for the power.. Used the supply for charging a few GPS's that used the same size connection for recharging NiMH batteries.)
    I stand corrected.. 3.5-Amp..   Right now, I'm running my Pi, with a clipped A to Mini-B2.0 (Samsung style Mini 5-pin), connected directly to the power in socket of the USB hub, which means I now have a freed-up USB socket for another device.  Slowly assembling a similar design keyboard case for my Pi, but all flat-fit boards.. (If I had access to a laser cutter, I would, but....)  It looks like an oversized Commodore C64, with the pin header brought through to the center.. (actually a glued-in-place IDC connector, instead of the card-edge Ben used.)  Still haven't gotten adventurous connecting to it..
    Stephen
    Stephen
