Ben Heck Featured Content
  • Ben Heck Featured Content
Documents See Ben Heck's Raspberry Pi Build Episode -- Episode 45
  • Author Author: joeman
  • Date Created: 6 Jul 2012 2:24 PM Date Created
  • Last Updated Last Updated: 4 May 2012 7:24 AM
  • Views 4685 views
  • Likes 8 likes
  • Comments 17 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
You have been asking for it, so we're finally bringing it to you! A retro computer for only about $35? Watch Ben build a retro-styled computer using the Raspberry Pi!
Click Here for access to all the supporting files you will need to replicate this build!
Check out more Raspberry Pi Projects in Ben Heck's Raspberry Pi Builds!
  • mod
  • raspberry
  • pi
  • mods
  • build
  • heck's
  • giveaway
  • episode
  • build_challenge
  • raspberry_pi
  • rpiexpert
  • ben
  • show_idea
  • german
  • tbhs_ep
    Silly question (really basic in electronics), but Ben splices the cable from the several amp PS and then splits it to the MicroUSB and to the USB Hub.
    I was wondering how did he connect the power to the MicroUSB connector?  (Was there an adapter board (MicroUSB breakout board you can solder the power to) Did he unsolder the MicroUSB connector and then solder power directly to it?)
    Is there any risk of too much amperage?
    thanks,
    James
    thanks,
    James
  • jlcarender
    jlcarender over 14 years ago in reply to e14 Contributor
    James, The only silly question is one that is not asked. He connected a micro usb plug to the dc socket then just plugged it into the raspberry pi.
    There should not be a problem with the increased amperage because it will only draw what it needs.
    As you attach more peripherals the more amperage it will need.
    I hope i have answerd your question.
                                                      Thanks Joe
  • Ramu
    Ramu over 14 years ago in reply to jlcarender
    Yes because power suply amperage is a maximum what power suply can give out. You have to be avare not to plug in a pover suply vith more voltage on it. Mobe voltage, then needed can burn your device. So when you are selecting a power suply, voltahe has to be the same as ment for the device, and amperage the same as on the divice or more image
