Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben Heck’s Super Soldered Atari 2600 Episode -- Episode 226
  • Author Author: pchan
  • Date Created: 25 Feb 2016 5:53 PM Date Created
  • Last Updated Last Updated: 19 Feb 2016 8:24 AM
  • Views 4287 views
  • Comments 11 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
In this episode Ben solders an entire Atari 2600 system from scratch. In a future episode he will test it out and create a cool case around it.
Supporting Files
Click Herefor access to all the supporting files you will need to replicate this build!
  • episode 226: ben heck’s super soldered atari 2600
  • hack
  • heck's
  • ben_heck
  • heck
  • ben
  • tbhs_ep
  • bh_buildkit
  • kingrahl
    kingrahl over 10 years ago +1
    Great episode. Lots of handy tips for the part time solderer. I was hoping for a bit more cautionary mistakes explained. Such as: Bad solder - Sometimes I get burnt solder spots. This may be from old solder…
  • makerkaren
    makerkaren over 10 years ago +1
    There have been some Youtubers asking about what solder Ben uses. Since I can't post pictures there, I will post it here. This is the solder Ben uses.
  • kingrahl
    Great episode. Lots of handy tips for the part time solderer. I was hoping for a bit more cautionary mistakes explained. Such as: Bad solder - Sometimes I get burnt solder spots. This may be from old solder, but I've had this happen with new. Flux problems. Usually with thicker solder. And the solder eating away at my tips. When I buy them new they have a silver coating on the tips. When I use them, it starts flaking off (or I scrape off the carbon), leaving the copper underneath it exposed. Any advise on buying or maintaining solder tips would be helpful.
    If you make a "Soldering 101 Part 2", it would be helpful if you addressed these problems I get. Maybe make a DIY Solder Station episode.
    shabaz over 10 years ago in reply to kingrahl
    1. Some of the cheaper irons just get hot in a fairly uncontrolled manner, others self-measure the tip temperature, and adjust power accordingly, i.e. they are temperature controlled. You want the latter, don't even consider the former.
    2. Don't ever scrape the tip or press hard with it. For cleaning, use a special wire wool designed for this, or a damp sponge designed for this, and nothing else. Buy these items from a reputable electronics supplier (such as Farnell/Newark), not ebay, Amazon third party sellers and so on, because would you know the difference between types of wire wool?
    3. Use solder specifically intended for electronics work, such as this Multicomp 507-1227 Multicomp 507-1227 . Again, consider where you're buying it from.
    4. You likely won't need additional flux provided what you're soldering is nice and clean. Otherwise use a small quantity of flux such as from this Circuitworks flux penCircuitworks flux pen.
    Usually the solder station is designed to work in harmony with the soldering iron, so I don't get the need to build a solder station when the iron manufacturer will have already optimised their station for use with their iron. I can't see much cost saving building your own either.
    There are tons of other hints/guidelines around, these are just an example. Everyone has different product recommendations and slightly different workflows. What I can say is that if you follow the basic points listed above, your tips should give you many years of service. Replacing tips is an extremely rare event. I've not replaced any tips for about 3 years.
