Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben Heck’s Mechanical Television Part 1 Episode -- Episode 230
  • Author Author: pchan
  • Date Created: 24 Mar 2016 8:27 PM Date Created
  • Last Updated Last Updated: 18 Mar 2016 8:24 AM
  • Views 1878 views
  • Comments 6 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
In this episode Ben begins making a mechanical television using old records, a flash light, a drill motor and some Photoresistors.
Supporting Files
Click Herefor access to all the supporting files you will need to replicate this build!
  • hack
  • episode 230
  • ben_heck
  • episode 230: ben heck’s mechanical television part 1
  • heck
  • ben
  • tbhs_ep
  • rouverius
    rouverius over 10 years ago
    Baird's process of image capture seems quite novel these days. I wonder why the photocells are not behind the lens and Nipkow disk; the equivalent to modern video camera. It is because the photocells would not be sensitive enough?
    As for the receiver, you might want to look into D.B Gardner's "Mirror-Screw" system. It seems to give a brighter and larger image than the Nipkow disk. There are strips of mirrors for each scan line incrementally fixed to the axis of a spinning motor. The signal light source goes through a narrow slit and is reflected by one of the strips of mirror spinning by. This means that the screen size is as wide as the mirror strips and should have a rather wide viewing angle.
    The only downside is that I don't have enough information to know if Baird's image encoding can be matched with Gardner's mirror-screw. But it would be interesting to see if it works.
    Anyway, here is a pretty interesting site about the different versions of mechanical televisions: http://www.televisionexperimenters.com/Links.html
  • rouverius
