Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben Heck’s Mechanical Television Part 2 Episode -- Episode 233
  • Author Author: pchan
  • Date Created: 14 Apr 2016 7:53 PM Date Created
  • Last Updated Last Updated: 8 Apr 2016 7:24 AM
  • Views 3036 views
  • Comments 15 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
In this episode Ben continues to make a mechanical television using old records, a flash light, a drill motor and some Photoresistors.
Supporting Files
Click Herefor access to all the supporting files you will need to replicate this build!
  • hack
  • episode 233: ben heck’s mechanical television part 2
  • ben_heck
  • ben hack
  • heck
  • ben
  • tbhs_ep
    e14 Contributor over 10 years ago +1
    I watched episodes out of release order (Mechanical TV 1+2 then luggage detective) so I don't remember which episode had Felix start going over how he uses Linux, but I want to encourage you to show more…
    Please revisit!!
    1. Analog brightness signal !!!! The source brightness should directly control the playback light brightness. Simple analog stuff. Get rid of the comparators here.
    2. Sync records with some sort of analog encoder, (potentiometer, ideally) so you can get high speed, and absolute positioning.
    3. Servo the playback motor so it is in sync with record motor. Simple servo circuit here: If the playback motor is ahead of the record motor, the comparator goes low. If the playback motor is behind the record motor, the comparator goes high.
    4. Low pass filter the comparator output, (capacitor in the feedback loop of the comparator) so it becomes a slow moving voltage. Put a high current buffer (power amp...) on the filtered comparator output that directly drives the playback motor. Boom, synchronization!
    5. Transmit the record brightness signal and the record encoder position over two AM radio signals. It is TV after all!
    OTHER IDEA:
    Instead of a spinning record, use lasers and a XY mirror control, like a barcode scanner. Use the mirrors from a laser printer or barcode scanner? Way better resolution. LASER TV!!!
    Please revisit!!
    OTHER IDEA:
