Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben Heck’s Mechanical Television Part 2 Episode -- Episode 233
  • Author Author: pchan
  • Date Created: 14 Apr 2016 7:53 PM Date Created
  • Last Updated Last Updated: 8 Apr 2016 7:24 AM
  • Views 2672 views
  • Comments 15 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
In this episode Ben continues to make a mechanical television using old records, a flash light, a drill motor and some Photoresistors.
Supporting Files
Click Herefor access to all the supporting files you will need to replicate this build!
  • hack
  • episode 233: ben heck’s mechanical television part 2
  • ben_heck
  • ben hack
  • heck
  • ben
  • tbhs_ep
  • Former Member
    Former Member over 9 years ago +1
    I watched episodes out of release order (Mechanical TV 1+2 then luggage detective) so I don't remember which episode had Felix start going over how he uses Linux, but I want to encourage you to show more…
  • RovertScott
    RovertScott over 9 years ago
    I have two ideas on how to make it work.
    DIRECT DRIVE MECHANISM (Sony Walkman Disk Drive)
    1. Use a single motor with a 3D printed gear to drive smaller gears attached to the Nipkow Disk shafts.
    2. The gears ensure that the Nipkow disks remain in sync and at constant speed as they rotate.
    or...
    MANUAL TUNING W/ ANALOG MAGIC EYE
    1. Use two motors to run each Nipkow Disk independently.
    2. Add an LED/Photodiode to the bottom of each Nipkow Disk in order to control a RED or GRN LED.
    3. As the outermost hole passes the LED/diode, it will cause its respective RED or GRN LED to flicker.
    4. The LEDs flicker frequency will illuminate a specific portion of a color gradient printed on a transparency above it.
    5. This will create a needle effect, allowing the speed of both disks be adjusted with pots.
    6. The motors can also be disabled momentarily, with a button press, to allow one disk to fall behind and hopefully sync.
    7. Then it will only be a matter of bringing the needles together and to the center of he indicator.
  • RovertScott
    or...
