Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben's Home-Brew Solder Reflow Oven 2.0 Episode -- Episode 116
  • Author Author: pchan
  • Date Created: 17 Jan 2014 3:24 PM Date Created
  • Last Updated Last Updated: 10 Jan 2014 8:24 AM
  • Views 7276 views
  • Comments 39 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
Ben's fed-up with the difficulty of soldering surface-mount components by hand and builds a new reflow oven to keep in his shop. He transforms an inexpensive toaster over into a vital tool for electronics engineers and tinkerers. In this updated oven, he uses two thermal couples to ensure even heat distribution and effective reflow.
  • 116:
  • reflow
  • ben's
  • solder
  • episode
  • 2.0
  • oven
  • ben_heck
  • heck
  • ben
  • tbhs_ep
  • home-brew
  • colecago
    colecago over 12 years ago in reply to mazzmn +1
    I'm not sure, but I bet most IC sensors wouldn't work well inside an oven, too hot. As for the Thermocouple, you don't need the translation IC, you could just use an Op-amp and math if you know the specs…
  • Sabrina
    Sabrina over 12 years ago in reply to e14 Contributor +1
    Hi- You can see the details available for this show on Ben's blog- Episode 116 Project Files
  • bigdog1
    bigdog1 over 11 years ago in reply to clem57 +1
    thank you.
  • benheck
    benheck over 12 years ago
    http://www.element14.com/community/community/experts/benheck/blog/2014/01/17/episode-116-project-files
  • colecago
    colecago over 12 years ago in reply to benheck
    For anyone building at home and modifying the profiles
    int profiles = 0;
    int profile[4][6] = {
        75,140,45,125,205,20                                    }
    String profileNames[4] = {
      "Ol' Fashioned Pb", "New Fangled RoHS", "Profile 3       ", "Profile 4       "
    the format of the profiles is {Ramp 1 0-255, 1st target temp, hold seconds at 1st target, Ramp 2, 2nd target temp, hold seconds at 2nd target}
    Ramp rate is kind of a misnomer, its just the analog write value but because our relay is a zero cross and we aren't accounting for the cross, it doesn't exactly work as good as a PWM value would.
    The ROHS profile definitely needs changing, probably a 220 target.  Your results may vary but you will definitely have to tweak for your own oven and possibly it could change depending on your board as well.
  • colecago
    int profiles = 0;
    e14 Contributor over 11 years ago in reply to colecago
    Hi,
    If I understand this correctly the profile is broken into triplets (ie PWM,Temp, Sec to hold @ temp) and that repeats. So looking at this there it ramps twice but my question if my assumptions are correct is can you add another triplet on to the profile (ie preheat triplet, soak triplet, reflow triplet)?
    Thank you.
  • colecago
    colecago over 11 years ago in reply to e14 Contributor
    It's been awhile but I don't think the code is set up that way, its set to ramp to a first setpoint, the soak, then ramp to the reflow temp, it holds, then turns off.  You could modify the code to allow a third setpoint yourself though.
