Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben's Home-Brew Solder Reflow Oven 2.0 Episode -- Episode 116
  • Author Author: pchan
  • Date Created: 17 Jan 2014 3:24 PM Date Created
  • Last Updated Last Updated: 10 Jan 2014 8:24 AM
  • Views 7276 views
  • Comments 39 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
Ben's fed-up with the difficulty of soldering surface-mount components by hand and builds a new reflow oven to keep in his shop. He transforms an inexpensive toaster over into a vital tool for electronics engineers and tinkerers. In this updated oven, he uses two thermal couples to ensure even heat distribution and effective reflow.
  • 116:
  • reflow
  • ben's
  • solder
  • episode
  • 2.0
  • oven
  • ben_heck
  • heck
  • ben
  • tbhs_ep
  • home-brew
  • colecago
    colecago over 12 years ago in reply to mazzmn +1
    I'm not sure, but I bet most IC sensors wouldn't work well inside an oven, too hot. As for the Thermocouple, you don't need the translation IC, you could just use an Op-amp and math if you know the specs…
  • Sabrina
    Sabrina over 12 years ago in reply to e14 Contributor +1
    Hi- You can see the details available for this show on Ben's blog- Episode 116 Project Files
  • bigdog1
    bigdog1 over 11 years ago in reply to clem57 +1
    thank you.
  • benheck
    benheck over 12 years ago
    http://www.element14.com/community/community/experts/benheck/blog/2014/01/17/episode-116-project-files
  • matas1
    matas1 over 12 years ago in reply to benheck
    Hi,
    I'm new at this but i love to learn new stuff.....I would like to make this, but beside just copying your thing, i'd like to add network access and a web server where i could set the values, and monitor progress...(timer, current temp, etc...)
    What are the limits of the SPI ?
    will i run into a problem if i grab a tft touch screen, ethernet shield, wifi shield, and those two sensors?
    if yes, is there some way to avoid it? other MCU? 1-way type sensors?
    what are the memory restrictions? i'd like to avoid SD cards if possible.
    thank you
  • colecago
    colecago over 12 years ago in reply to matas1
    I believe the SPI I was using for those sensors was bit-banged, so it was kind of slow.  I wouldn't recommend putting all of those things on a SPI bus with an Arduino.  The Arduino is a pretty limited device.
    Maybe look into using a Raspberry Pi instead, they have a TFT touch screen that fits on it, it already has ethernet, and there are a lot of tutorials on SPI sensors and I/O control with it.
  • matas1
    matas1 over 12 years ago in reply to colecago
    Well, I have a RasPi but I really don't want to use an SD card, as they've proven unreliable (except for the most expensive ones). I would like to put it into an enclosure and have it in fire and forget manner, once I've done everything I need on it. Most likely I'll not be the only one using it, moving it around, loaning it to friends, etc. and I want to minimise the risk of anything going awry. RasPi without SD card would be the single solution to my problem... Is there such a thing?
    I would require ethernet shield only to configure wireless connection (or something like that, don't have that concept worked out in my head yet.) I don't want to reprogram arduino everytime a friend asks me to lend him the oven so he can connect to his own wireless.
    One of the ideas I came across is connecting arduino via serial port to TL-WR703N wireless router
    One is using Spark and cloud.
    and so on...
    I don't know...Its been occupying my mind for a week now, making me losing sleep because of all the possibilities image
    I'm lost...
  • matas1
    and so on...
    I'm lost...
