Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben's Home-Brew Solder Reflow Oven 2.0 Episode -- Episode 116
  • Author Author: pchan
  • Date Created: 17 Jan 2014 3:24 PM Date Created
  • Last Updated Last Updated: 10 Jan 2014 8:24 AM
  • Views 7276 views
  • Comments 39 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
Ben's fed-up with the difficulty of soldering surface-mount components by hand and builds a new reflow oven to keep in his shop. He transforms an inexpensive toaster over into a vital tool for electronics engineers and tinkerers. In this updated oven, he uses two thermal couples to ensure even heat distribution and effective reflow.
  • 116:
  • reflow
  • ben's
  • solder
  • episode
  • 2.0
  • oven
  • ben_heck
  • heck
  • ben
  • tbhs_ep
  • home-brew
  • colecago
    colecago over 12 years ago in reply to mazzmn +1
    I'm not sure, but I bet most IC sensors wouldn't work well inside an oven, too hot. As for the Thermocouple, you don't need the translation IC, you could just use an Op-amp and math if you know the specs…
  • Sabrina
    Sabrina over 12 years ago in reply to e14 Contributor +1
    Hi- You can see the details available for this show on Ben's blog- Episode 116 Project Files
  • bigdog1
    bigdog1 over 11 years ago in reply to clem57 +1
    thank you.
    Where can I find the list of used components and the schematics?
  • Sabrina
  • sb72104
    sb72104 over 12 years ago in reply to Sabrina
    hey in this file all I see is the code to run it.  I would like to see the avr board schematics "or where to get it" that he uses.  this is my first mod and would like to make sure I get everything right.  thank you
  • colecago
    colecago over 12 years ago in reply to sb72104
    Its basically an Arduino Uno, you could just use an Uno.  You can get an idea of how things were wired by looking at the code, it has callouts for all the pins.  Sorry, there is no schematic currently unless Ben has done one since.
    e14 Contributor over 12 years ago in reply to Sabrina
    Like Stephen is mentioning: There is only the program-file for the Arduino(?).
    What I need is the BOM, so I know which components Ben has used for this mod.
    In the movie there is a hint to look at ebay for the thermocouple interfaces, but which are used here?
    The SolidState used? etc...
  • colecago
    colecago over 12 years ago in reply to e14 Contributor
    Not sure what Solid State relay was used exactly, they tend to be expensive, I think that was his ebay comment to try there if you can't find a cheap one elsewhere.  This is probably comparable to what we used
    SSR http://www.newark.com/opto-22/240d10/ssr-panel-mount-280vac-32vdc-10a/dp/96F1061
    Here is the thermocouple stuff
    Thermocouple reader http://www.adafruit.com/products/269
    Thermocouples Ready-Made Insulated Thermocouples, Models 5TC-GG, 5TC-TT  (5TC-GG-K-30-36)
    and for LCD we used a generic 16x2 character display he had lying around the shop.
  • sb72104
    sb72104 over 12 years ago in reply to colecago
    I guess I need to find a good Arduino tutorial.  I have never messed with one.
  • sb72104
