Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben's Let's Try PCB Etching Episode -- Episode 134
  • Author Author: pchan
  • Date Created: 8 Sep 2014 8:37 PM Date Created
  • Last Updated Last Updated: 16 May 2014 7:24 AM
  • Views 1664 views
  • Comments 5 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
Ben is always looking for new tools and processes to help with all the projects he builds. He's got a CNC mill, laser cutter, and a 3-D printer, but hasn't found a way to whip up a PCB at his shop. He's hand wired many circuits, but this can be tedious. He's designed PCBs in Eagle and sent them off for production at a board house, but this doesn't help when he wants a PCB the same day. In this episode, Ben experiments with three methods of PCB etching and shares the results.
  • hack
  • try
  • etching
  • ben's
  • let's
  • 134:
  • pcb
  • episode
  • essentials
  • ben_heck
  • heck
  • ben
  • tbhs_ep
    I use transparency film to print to instead of paper. Works pretty well.
    Like: http://amzn.com/B003U6KYO8
  • askuechler@gmail.com
    askuechler@gmail.com over 11 years ago in reply to e14 Contributor
    Thanks, I tried several types of paper for the direct toner transfer method. For single sided pcb this works fine, but getting double sided pcbs is a pain. I switched to photosensitive pcbs and a uv enclosure. It is some more fiddling with chemicals but it is much easier to line up both sides correctly. The best was whatsoever is to keep it a single sided pcb using zero ohm resistors to skip traces when necessary (or use the pads to attach wire bridges).
    best regards
    Andreas
