Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben Heck’s Crowdsourced Can Crusher Part 2 Episode -- Episode 154
  • Author Author: pchan
  • Date Created: 10 Oct 2014 1:36 PM Date Created
  • Last Updated Last Updated: 3 Oct 2014 7:24 AM
  • Views 956 views
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
Ben continues building his crowdsourced can crusher, creating it piece by piece to make sure everything works before routing parts on the CNC.
  • hack
  • part
  • 2
  • crowdsourced
  • episode
  • crusher
  • heck’s
  • ben_heck
  • 154:
  • heck
  • ben
  • can
  • tbhs_ep
  • kingrahl
    kingrahl over 11 years ago
    Dear Ben,
    Congratulations! It works. On your small gear that's slipped on the stepper motor: To keep your set screw from slipping, Drill/cut a hole through the side of your gear at a 90 degree angle to your set screw hole. This will need to be flat on bot sides so you can slip a metal nut inside. The nut will need to be a size to fit on your set screw.  It will need to sit far enough away from the outside edge that you do not make that wall too thin and brake when applying pressure. We've used this method in 3D printing plastic gears for our stepper motors.
