Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben Heck’s Xbox One S Laptop Episode -- Episode 271
  • Author Author: pchan
  • Date Created: 5 Jan 2017 7:48 PM Date Created
  • Last Updated Last Updated: 30 Dec 2016 8:24 AM
  • Views 5651 views
  • Comments 25 comments
element14's The Ben Heck Show
Community Feedback
Featured Bonus Content
See All Episodes
Ben assembles an Xbox One S Laptop using parts from a previous teardown of an Xbox One S. The new laptop includes 3D printed parts, an aluminum base cut with a CNC machine, a new power supply to power both the Xbox and LCD screen, and smaller fans powered by a rigged circuit using a Tip 102.
The major components of the Xbox One S are a Blue Ray Drive, Power Supply Unit, a Motherboard, and a Hard Drive. Ben takes the motherboard and scans an image of it in Adobe Illustrator. He uses laser patterns to knock holes in the board. This gives him as many options for mounting this as possible.
He puts together all the Xbox One components. He's extended the power cable of the blue ray drive, he's moved the hard drive, he's put the front panel PCB at a right angle and ported out the buttons (eject, bind, and power), he's moved the wifi module to an end degree angle, and he's using the new short HDMI cable to connect to a screen.
He replaces the power supply with a more powerful unit as the added power is needed for the LCD screen. He also replaces the large fans with two smaller fans for his laptop. By keeping the control line, the system can throttle the fans up and down as needed by heat load. To do this he rigs up a circuit using a Tip 102.
The 12 V fans are wired in parallel, 12 V comes from the console and goes into the positive wire, and the negative wire from the fans goes into the collector of the Tip 102 NPN Darlington Transistor allowing you to switch the current on and off. The control line from the Xbox goes through a 1K resistor and into the base of the Tip 102. Finally, the emitter of the Tip 102 goes into ground. The Tip 102 acts as the circuitry inside the fan did allowing the fan to turn on with their speed controlled by the system.
Ben cuts the aluminum base for the Xbox One S laptop with a CNC machine. He can then attach the 3D printed wall sections to the aluminum. Next he attaches the power supply and the blue ray drive to the aluminum base. He then makes adjustments to allow the motherboard to fit.
Before closing the inside off with 3D printed parts, Ben goes over what's inside. There's a new power supply with 13.9 amps, a blue ray player, a wifi module, hard drive, wireless controller module, and a control panel. There's a driver board for the LCD and a heat sink for the APU.
  • hack
  • episode 271: ben heck’s xbox one s laptop episode
  • heck
  • ben
  • tbhs_ep
  • koolkaze
    koolkaze over 9 years ago +1
    Hello, This was the project I waiting for. It's an awesome build, great ideas to start with, a nice design and a functionnal one. On each build, you take time to explain clearly what you're doing and the…
  • the_sellout
    the_sellout over 7 years ago
    I love this episode, I am going to try it out and see if I can
  • dsedohr68
    dsedohr68 over 7 years ago
    You mentioned that the scanner only has an element that is about one to two inches wide.  Is there a scanner that has an element that is the full width of the scanner?
  • maggo87
    maggo87 over 7 years ago
    Brilliant project, it was the reason I joined the site, looking at making one myself but need to look into he power supply a little as I going to make mine with a large 17" or 19" screen.
  • makerkaren
    makerkaren over 8 years ago in reply to uermilo
    Don't really have any pictures and we already gave away the laptop so I can't take new pictures either. The outside was engraving plastic with holes for the buttons to show through and there was a mother piece of plastic behind the buttons holding them in place.
  • uermilo
    uermilo over 8 years ago
    Was wondering if you have a photo. or a diorgram of how you ported out the buttons (eject bind and power)am trying to make something about the same you did just canNot get the buttons to work
    if you can please help it would help a lot and thanks
    Ermilo (Junior)
  • fog187
    fog187 over 8 years ago
    Does anyone know what power supply Ben used? I tried to find one but couldn't..
    Please help.
  • davydp
    davydp over 9 years ago in reply to makerkaren
    Ok no problems actually finally find screen 13.3" FHD have to wait for it in post tho lol
  • makerkaren
    makerkaren over 9 years ago in reply to davydp
    The screen is one that Ben had on hand from another project. It is not commercially available unfortunately.
  • davydp
    What screen was used in this?
    As its hard to find smaller screens ie smaller than 21.5inch FHD
    Also been testing running off DC-DC power supply to run off battery/solar
  • sumjay
    sumjay over 9 years ago
    Does anybody know what power supply Ben used? I tried to find one but couldn't..
