Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Ben Heck’s Auto Tracking Camera Part 2 Episode -- Episode 174
  • Author Author: pchan
  • Date Created: 26 Feb 2015 4:25 PM Date Created
  • Last Updated Last Updated: 20 Feb 2015 8:24 AM
  • Views 2615 views
  • Comments 8 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
Max helps film this week's episode as Ben completes the auto tracking camera that will follow an object on his work surface. Watch how it works here.
Supporting Files
Click Herefor access to all the supporting files you will need to replicate this build!
  • hack
  • part
  • 2
  • episode
  • tracking
  • 174:
  • camera
  • heck’s
  • ben_heck
  • heck
  • ben
  • auto
  • tbhs_ep
  • bh_buildkit
  • clem57
    clem57 over 11 years ago in reply to patgau215 +1
    Yeah! Cut power and the camera droops. Turn on power and the camera pops up.
  • damferdinezm
    damferdinezm over 5 years ago
    Hello!
    I am a senior in Biomedical Engineering in Boston and my project consists in building a camera system for an OR. Your project here would greatly improve our system, I was just wondering what are the electronic components you used for your circuit?
    Thank you!
    beacon_dave over 10 years ago in reply to clem57
    My vacuum cleaner may disagree with you there Clem... image
    How about a follow cam variation of this which can track Ben in the workshop. However the design needs to keep in mind that Karen or Felix are sometimes with Ben so the camera needs to be able to zoom in and out to allow for this.
    Optional add-ons might be follow spots which keep Ben well illuminated whilst in frame.
    There is a real world application for this in the likes of teaching where often the trainer needs to be filmed as they move around the room between flipchart, whiteboard and desk/lectern. However existing camera tracking systems can be expensive and often rely upon ultrasonic or IR beacons to be worn.
    Although wearing a neon green tie or shirt might work with the likes of the Pixy camera, it may not be the best of approaches here. The Panasonic Grid-EYE IR sensor might work though as it can identify multiple people, position, and direction of movement.
  • clem57
    clem57 over 10 years ago in reply to beacon_dave
    But dust floats! image
    The droop should help keep the dust off the lens when not in use image
  • shapeshifter
    shapeshifter over 11 years ago
    Interesting show and concept.
    To keep the camera from drooping, you need a bigger cradle that can extend up the sides of the camera, and place the pivot point through the center of gravity of the camera. (Actually, through the center of gravity of the camera and the moving cradle part.)
    And while the big red switch taped to the side of the bench has a certain amount of appeal, what would make it much slicker is to hollow out the target object, place a battery and a very simple wireless transmitter in it, and a momentary button on the top. As long as the button is held, the transmitter is on, and the camera tracks the movement. Once aimed, let go of the button and move the target out of the way. The button should probably be recessed slightly so it doesn't get pressed accidentally by setting something on top of it, and therefore run down the battery.
  • clem57
    Yeah! Cut power and the camera droops. Turn on power and the camera pops up. image
  • patgau215
    patgau215 over 11 years ago
    For the Y axis try a servo, maybe geared. You can set the program to keep the servo powered to prevent the camera from moving. Now you just got to work out how to auto zoom the camera to different areas. Could also make a ceiling system that follows you around or goes between different spot in the shop. Just be worry if it takes you there is cake.
    Thanks Ben
    Pat
