Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Announcing Three New Builds! -- Episode 279
  • Author Author: pchan
  • Date Created: 2 Mar 2017 8:57 PM Date Created
  • Last Updated Last Updated: 24 Feb 2017 8:24 AM
  • Views 3651 views
  • Comments 17 comments
element14's The Ben Heck Show
Community Feedback
Featured Bonus Content
See All Episodes
The Ben Heck Team announces a major change on the show after receiving a lot of interest from community members who would like to see more detail in each episode and longer term builds.  By focusing on three long term builds they can give community members what they want to see, a more robust design and detail build.  In this episode you’ll see which builds they will be focusing on over the course of the next year and set the stage for their next major challenge in the evolution of the show.
Great Glue Gun Episode
Hackmanji Episode
Teensy Pinball Portable Episode
Over the next year the Ben Heck Team will be focusing on three long term builds.  Two were chosen by Ben while a third was chosen by community members by a poll.
  • hack
  • the ben heck show
  • announcing three new builds
  • new_builds
  • new builds
  • episode 279: announcing three new builds!
  • heck
  • ben
  • tbhs_ep
    beacon_dave over 9 years ago in reply to cstanton +1
    It would perhaps be one step away from becoming a mobile app. Wires should help make it a bit more tangible. I remember using similar style logic boards back in college and after weeks of theory it was…
  • Blacksheep32
    Blacksheep32 over 9 years ago +1
    For the Logic game- I'm thinking something with a slight departure from the original Hackmanji. What if you have a single board for four players with a four by five LED array at the top indicating whose…
    DAB over 9 years ago in reply to cstanton +1
    Perhaps, but from my observations, it would make a user interface more accustom to what current game players know. After all, how many games do you see any more where physical pieces need to be moved?…
  • tm14
    tm14 over 9 years ago in reply to tm14
    Instead of printing parts on the 3D printer, could you print molds instead?
    https://howchoo.com/g/mgyymza3nzi/3d-printing-molds-for-rubber-abd-plastic
  • makerkaren
    makerkaren over 9 years ago in reply to dtarsky
    Typically sheet plastic is more expensive than wood by a pretty large margin depending on type, so while it would look cooler, I don't think it would improve on the expense. If these get produced, maybe that could be a bonus add-on someone could select when purchasing a kit.
  • makerkaren
    makerkaren over 9 years ago in reply to Blacksheep32
    That would be great! Ben said it would really help him with the build. Send me your email and we'll make arrangements. Thanks so much!
    ~Karen
  • makerkaren
    makerkaren over 9 years ago in reply to DAB
    Without turning it into a tablet game, I'm not sure how to show which wire is connecting which inputs. If you wait for Pt.1 of the new build, you will see what we have in mind in terms of I/O. It makes it tricky to make everything digital.
  • dtarsky
    dtarsky over 9 years ago
    I like the mini pinball project. Would it maybe shave a few bucks off if you made the box out of something transparent like plexiglass? I've wanted to make a transparent custom pinball machine since the late 80's thinking it would be super cool to see all the internals such as the solenoids/actuators and when multi balls are piling up to be dispensed.
  • cstanton
    cstanton over 9 years ago in reply to DAB
    Perhaps that's a problem, people need a break from what their norm is to transition into a different field where it isn't the norm?
  • bearfootleather
    bearfootleather over 9 years ago in reply to bearmob
    Hi all,
    Just to expand on my original thought. It was for the layout etc of those
    switchboards as opposed to the actual wires and plugs as I agree they are
    long gone by now.
  • bearmob
    bearmob over 9 years ago
    Originally posted this in the wrong thread I guess.
    This is in reference to the hackmunji project.
    First for names of ports, It should likely be something along the lines of Output, Input, and Result.
    You guys were talking about in the video moving the LEDs to one side of the board, however it is my understanding that only some of the outputs are active at a given time.. Correct?
    This would cause a huge mental disconnect and likely add more confusion. You are shrinking the board anyways, why not build a light ring around the output and input ports. This would increase the visibility of them and likely no longer require scanning. If it still isn't enough try moving them to the short side (top and bottom currently), I think that would be more than enough. Having the LEDs removed from the port that they represent just seems like a bad idea.
    When talking about light ring, I am thinking along the lines of the Xbox ring of light, but obviously much smaller scale. I have even seen these on a device before I just can't think what it was.
    I just seen anigan post above about using RGB to get rid of 1 set of leds and I think this fits perfectly into this idea.
    bearfootleather in the thread I posted in had brought up old telecom switchboard ports/wires as a good idea instead of banana plugs, but no clue if they still are cost effective being their primary use is dead.
    If those are a dead end you likely could look at what multi-meters and other testing equipment use to connect the leads to the device. I have no idea the longevity of them, but they for sure are cheap.
    For longevity reasons there are few connectors that are designed for such frequent plugging and unplugging in a package that would fit the scale of this project.
    If neither of these other options work I think you just have to look at what banana plugs on the cheap side are in bulk orders. Skimping here would seem like a really bad idea and stress what is already the most common failure point.
    The wire board is great for us retro types, but totally foreign to the newer generations.
  • anigan
    anigan over 9 years ago
    In the hackmunji rededign you could remove the result LED and repurpose the answer led.  You could make that an RGB led and have it red if you want it off or blue if you want it on.  Theb green when its correct (on or off if you want).
