Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Super Glue Gun 03: Ungluing the Great Glue Gun -- Episode 289
  • Author Author: pchan
  • Date Created: 11 May 2017 8:50 PM Date Created
  • Last Updated Last Updated: 5 May 2017 7:24 AM
  • Views 1867 views
  • Comments 6 comments
element14's The Ben Heck Show
Super Glue Gun
Featured Bonus Content
See All Episodes
The team gets back to work on the Super Glue Gun. Previously they worked on controlling the heating element with a triac and controlling the motor while extruding the glue through it. The team gets help from a community member who returns a previous super glue gun build to Ben.
Check out more Super Glue Gun Episodes
Super Glue Gun Ideas
The Motor on the previous glue gun build is smaller than some of the other motors they tried. It uses a SN754410E Quadruple Half-H Driver. The Mains go straight to the heater core. The 12V adapter goes to a 5V stepdown for the microcontroller. The glue gun has a temperature sensor on it so if it’s not warm enough the motor will not extrude. The motor driver is driven at 12 V.  Ben demonstrates the control the glue gun gives him by writing in cursive with the glue gun.  A design flaw of the previous glue gun is that the heat from the motor is causing the glue that held the motor in place to fall off.
Ben rigs up an extrusion test. He 3D prints a part to test the motor with a larger bearing. After testing the extrusion its determined that the glue gun needs a tougher base plate.  Adding a plate prevents the idler-wheel from being pushed out with the force, keeping all the force on the glue stick, allowing it to extrude. Unlike the original glue gun, this glue gun isn’t spring loaded meaning it’s easier to build.  Finally, they refine the form using foamcore and are able to get the glue gun to extrude glue using a fairly small DC gear motor.
Disclaimer
  • hack
  • episode 289: super glue gun 03: ungluing the great glue
  • heck
  • ben
  • tbhs_ep
    DAB over 9 years ago
    Great episode.
    I have never finished a project in which I ended with a lot of potential project improvements.
    That is why I was surprised when Ben started afresh.
    Going back to review the old design was the right step.
    After seeing the issues involved with loading a new glue stick, I thought perhaps adding a clip that could automatically feed new sticks as soon as the old stick cleared space.
    That way you could load say five sticks at a time if you have a lot of gluing to do, a long strip or a large area to glue.
    Just a thought,
    Great episode.
    Just a thought,
