Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Hand-Wired Z80 Basic Computer -- Episode 341
  • Date Created: 10 May 2018 6:59 PM Date Created
  • Last Updated Last Updated: 4 May 2018 7:24 AM
  • Views 3210 views
  • Likes 11 likes
  • Comments 12 comments
element14's The Ben Heck Show
The Learning Circuit
sudo Sergeant
See All Episodes
Seeing as everyone loves to a bit of intricate soldering, it's time for one last super solder episode! Ben is feeling nostalgic looking at his collection of CPUs so decides to use the z80 to create a basic Microsoft computer...giving him the perfect excuse to do lots of lovely soldering!
Disclaimer
  • retro computers
  • hack
  • episode 341: hand-wired z80 basic computer
  • ben heck
  • z80
  • computers
  • cpu
  • soldering
  • heck
  • ben
  • tbhs_ep
  • COMPACT
    COMPACT over 8 years ago +4
    Here's a picture of one of my ancient hand assembled Z80's. Two serials ports on the left, two parallel user ports in the centre and the 10BaseT port on the right. It boasts Ethernet Internet connectivity…
  • mackan
    mackan over 8 years ago +3
    I would REALLY like to build a 6502 based computer but with a cool, old school front panel / console. You see, I am blind, and I would love to have a way to program my computer with switches and maybe…
  • dheald
    dheald over 8 years ago +2
    I'd build a 65C816 based machine and run an updated version of Commodore basic.
  • pa1
    pa1 over 5 years ago
    Where are the instructions?
  • COMPACT
    COMPACT over 8 years ago in reply to timeloop
    What do you exactly mean?
    USB-C has so many more bells and whistles than the original 2 wire USB doesn't have.
    Passing through limited power (up to 1A) is easy - the other functionality requires a whole bunch of smarts which a USB controller IC can provide.
  • COMPACT
    COMPACT over 8 years ago in reply to jw0752
    Thanks!
    The virtual CP/M network drives I use are fantastically fast; but they don't go click whirr whirr buzz like floppy drives.
    jw0752 over 8 years ago
    Nice project.
  • timeloop
    timeloop over 8 years ago
    Hey I have an question ? Is there a way to change USB out to usbc in an hub 4 port charger ?
  • COMPACT
    It boasts Ethernet Internet connectivity and runs CP/m from network storage.
    The terminal can operate using a serial port or Telnet.
    Most of the wiring is within the its Z84C15 Z80 System on Chip that can run @ 16MHz.
    It you look closely it's built on a Radio Shack protoboard.
    RIP - Radio Shack
  • COMPACT
    COMPACT over 8 years ago in reply to mackan
    I've built many 6502 family based systems. Do you need any help?
    To make things easier I suggest building a system using the R6511Q derivative.
    All you need to do is connect an EPROM, oscillator, some caps and resistors and you have an instant system.
    Optionally you can connect extra RAM.
    The R6511Q has inbuilt RAM - all 192 bytes!, Timers, parallel and serial I/O ports and 10 (TEN) Interrupts!
    If you really want to look at an 8 bit computer with banked memory - have a look at the later Z80 based microbees.  They have up to 1Mbytes of RAM (but usually 128-256).
  • Sean_Miller
    Sean_Miller over 8 years ago
    This was cool, particularly to see how Ben built the bus nodes.  I saw his similar Atari build a few years ago which inspired me to dig around and bump into Grant Searle's build.
    It evolved into a project that was featured on EEVLog last Christmas.
    The video was design to poke on Dave in jest, but in reality, our bus truly formed into what you see here - a true rat nest:
    https://youtu.be/vr8ROiYs8AQ?t=3m20s
    -Sean
  • mackan
    You see, I am blind, and I would love to have a way to program my computer with switches and maybe use vibrators instead of Blinkenlights. But wouldn't it be cool to be able to actually toggle in machine code directly into a system, like on the old IMSAI or Altair (or, even, PDP-11, although that was 16 bit...)
    I realise that the 6502 can't adress more than 64K of memory (since it is 8-bit), but I would also dream of putting more memory in it, but being able to toggle between banks, so that one potentially could write a modular OS for it, such as UNIX. On an 8-bit computer.
    Yeah... One can dream, right?
    DAB over 8 years ago
    Nice episode.
    Brought back memories of the days when we wire wrapped CPU and memory chips before committing to a PCB.
    No, I do not miss soldering all those connections or even doing the wire wrap.
