Ben Heck Featured Content
  • Ben Heck Featured Content
Documents Help Ben Create an Automatic Can Crusher -- Episode 3
  • Author Author: bluescreen
  • Date Created: 24 Oct 2010 11:24 PM Date Created
  • Last Updated Last Updated: 8 Oct 2010 7:24 AM
  • Views 5271 views
  • Comments 18 comments
element14's The Ben Heck Show
Connect with TBHS
Featured Bonus Materials
See All Episodes
Ben's friend The Longhorn Engineer challenges him to build an automatic, domestic can crusher. Ben also starts building the case for the Xbox 360 laptop.
Check out the Ben Heck BOM ListCheck out the Ben Heck BOM ListCheck out the Ben Heck BOM List
  • hack
  • an
  • automatic
  • he?
  • episode
  • 3:
  • does
  • quest
  • ben_heck
  • builds
  • heck
  • ben
  • crusher...
  • can
  • or
  • tbhs_ep
    e14 Contributor over 15 years ago
    Just a thought, perhaps the motor and worm gear assembly used in adjustable seats.  Not certain how much torque it can produce, but if it can move a former wisconsinite such as myself after a double order of fried cheese curds, it should have no problem crushing a little aluminum.
    A design note, perhaps a slide rod design similar to the slides on your cnc router
    another option  before going to that extreme a design change is to perhaps  mount the motor on a pivot so it can angle out ward as handle moves outward.
    you'd need to create a U shaped bracket that would go directly on the handle of the store bought crusher so as to allow you to insert the can.
    you'd of course want some sort of limit switch that tells the device it's crushed the can enough, and then a motor reversing circuit to open the crusher back up with another limit switch to break the latched relay once it's opened back up enough.
    another thought; if it were mounted sideways  with a slot on the back side for the crushed can to conveniently fall into your recycling bin below as the crusher opened back up.
    If these instructions are clear as mud as I assume they are, I could be convinced to illustrate these modifications in a video. A t-shirt perhaps.
    Happy modding,
    Deep C
    Happy modding,
    Deep C
    e14 Contributor over 15 years ago in reply to e14 Contributor
