element14's The Ben Heck Show
Forum CNC Router Designs
  • Replies 17 replies
  • Subscribers 35 subscribers
  • Views 2863 views
CNC Router Designs
benheck
benheck over 16 years ago
Attached are my designs for the CNC Router we did in Episode 2. There are certainly things I would do differently now, but it did function. I used PVC plastic, but MDF is a popular material for this as well.
You may need to modify it depending on the physical size of the stepper motors. I don't like when I see homemade CNC machines with motors hanging off the ends, so I made mine in-line. The side effect is the design and spacing is more aggressively tight, so a larger motor might not fit.
The cutting motor is a Porter Cable Laminate router. You can get one at Farm & Fleet for around $100.
I'll post the designs for the Xbox 360 laptop probably in Episode 6. Also, will offer the plans for Portable Work Bench whenever it shows up, probably episode 4.
CNC.zip
  • ckraft
    ckraft over 15 years ago in reply to e14 Contributor +1
    The SparkFun steppers won't be enough. For a CNC type machine you need lots of torque because you have to push a cutting tip around the material. NEMA 23's at a minimum. Something with lots of torque,…
  • weekendranger
    weekendranger over 12 years ago +1
    Ben, I wanted to find out what you are using to cut the plywood. I know you are using a laser cutter but I wanted to know what model or at lest the model of the laser that you use if you home brewed your…
  • bonestm
    bonestm over 16 years ago
    Thanks for posting the design. One question. What format is it in?  The payload inside the zip archive has no exetension or at least I don't see any.
    Thanks.
  • Ironaxe
    Ironaxe over 16 years ago in reply to bonestm
    There is the .ai & .eps File for Adobe Illustrator
    A PDF Version
    And a DXF & DWG Version inside the Package
    The only thing that is missing is a NC File ^^
  • bonestm
    bonestm over 16 years ago in reply to Ironaxe
    Got it. Thanks.
    e14 Contributor over 16 years ago in reply to bonestm
    Installed qcad and inkscape to use the files on my linuxbox. http://www.linuxcnc.org/ is a place to look at also.
    Ben, You Rock!
    You appeared to use a cnc router to create your router. As a DIY that does not do me any good. Also take a look at this site
    http://wiki.zentoolworks.com/index.php/ZEN-0707_DIY_Kit
    Zentoolworks has a kit available for $330. minus the electronics. A three axis driver is $99.
    I see you are using Artpath to route parts for the CNC. I have to work with that @#%@^@! everyday:(
  • benheck
    benheck over 16 years ago in reply to e14 Contributor
    Ah yes Gerber. Great hardware, crappy software.
    Remember when it took them almost 6 years to make a 32-bit version of their software after Windows 95 came out?
    e14 Contributor over 16 years ago in reply to benheck
    "Advanced Nesting features...." image
    between the eyes............image
