element14's The Ben Heck Show
Forum Raspberry Pi Model B laptop
  • Replies 25 replies
  • Subscribers 35 subscribers
  • Views 3420 views
  • raspberry
  • lcd
  • 3d
  • pi
  • custom
  • diy
  • 3d_printing
  • challenge
  • printing
  • laptop
  • laser
  • linux
cmb271
cmb271 over 14 years ago
Hey Ben, I wanted to know if you can show me the best way to go about building a raspberry Pi Model B laptop, I need something light, simple and possibly good for someone with limited equipment. The idea is you have the raspberry Pi and you install the main things that makes a laptop well a laptop which in my book is a monitor, a mouse pad, a keybored, USB ports, WIFI, and battery system, I made up some blueprints but due to my limited software at the time of this idea it was made using a simple paint clone (Linux User). I found a image of something similar to what I want yet I was something bigger, more like a 13 inch or something, please Ben try it out or atleast tell me what would be a good alternative.
  • benheck
    benheck over 14 years ago +1
    Here's a pic of a setup I'll build eventually. Raspberyy Pi, 2.4GHz wireless keypad (needs dongle). Asus N-10 Wi-Fi dongle (not shown) 7" LCD with touchscreen and HDMI from eBay.
  • benheck
    benheck over 13 years ago in reply to e14 Contributor
    Most MCU hobbyist stuff uses a buffer as level translation.
    You power the buffer with the target voltage (usually 3.3 volts) so it outputs at that level.
    Some 3.3v stuff is 5 volt tolerant, but the Raspberry Pi isn't. So you'd want to knock 5 down to 3.3 before letting it into the Pi.
    However, 3.3v coming out of the Pi is enough to trigger 5 volt logic, so you don't need a buffer in that direction.
    e14 Contributor over 12 years ago in reply to benheck
    Ben, why not make it an android tablet because android is on or about to be on the raspberry pi
    e14 Contributor over 12 years ago in reply to fustini
    I have been developing and testing a direct Pi Lapdock connection.... Still a few problems... Lid closed power out.... Potential solution : super capacitor....... Second problem... Burnt out D1 on Pi. Solution might be to wire the USB power to the HDMI pin 2 to provide the required current.
    Don't actually know why HDMI pin 2 requires +5volts?
    Above direct connect cable...
    Other photos of my test boards at @OpenECommunity twit
    Matthew John Ritchie
    Please let us know when you will build the laptop
