element14's The Ben Heck Show
Forum HP Pavilion tx2000z Resistive Touchscreen Challenge
  • Subscribers 32 subscribers
  • Views 850 views
  • mod
  • hack
  • hardware
  • build
  • build_challenge
  • idea
  • viewer_challenge
  • challenge
  • ben_heck
  • show_idea
I have a tablet - what the old definition of tablet meant. It's the HP Pavilion tx2000z with the resistive touchscreen that twists around. It has a great stylus.
Over two years ago, I ran an HD movie on it and the whole thing crashed. It wouldn't start for some reason. So I took out the hard drive, formatted it and I'm currently using it as an external storage device.
The tablet doesn't work because there's no hard drive. But, I'm sure the touchscreen still works.
My challenge is, what could be the best way to hack the tablet and make use of the still functional resistive touchscreen...? This could be a great show idea.
ACP
  • colecago
    colecago over 13 years ago
    Not super difficult, get an LVDS controller like this
    http://www.ebay.com/itm/LCD-Controller-Board-DIY-Kit-RTD2270L-Driver-LVDS-Inverter-Turn-LCD-to-Monitor-/110925504614?pt=US_Server_Boards&hash=item19d3ace066
    And a resistive touch screen to USB controller like this
    http://www.ebay.com/itm/4-wire-Resistive-LCD-touch-screen-panel-USB-port-controller-touch-panel-driver-/180836520468?pt=LH_DefaultDomain_0&hash=item2a1ab25214
    (they have 4 and 5 wire models)
    e14 Contributor over 13 years ago in reply to colecago
    Thanks for the response! However, I have no knowledge/experience whatsoever with doing this kind of stuff. That's why I posted this here. What do you suggest I should do...? I really want to make good use of that touchscreen...
  • benheck
    benheck over 13 years ago
    I had that tablet, or a very similar model. It was a POS.
    Resistive touchscreens are very easy to use, there's basically 2 planes of resistance, left and right, up and down, thus 4 connections on the pins.
    Just keep in mind there's a certain point where the cost of reusing old electronics exceeds their value - like putting gold plated rims on a 1982 Chevette.
    e14 Contributor over 13 years ago in reply to benheck
    Hello Ben,
    I saw that you kinda referenced my idea on the latest TBHS. I completely understand.
    But, being a stubborn person image, I keep thinking of ways that just the touchscreen could be salvaged. One way is to turn it into a digital notepad like the one you see on refrigerators.
    I have thought of many more, but I don't want to waste your time imageimage.
    Thanks anyways,
    ACP
  • benheck
    benheck over 13 years ago in reply to e14 Contributor
    It's a very common question, re-using old laptops. 5-7 years ago it may have been worth it. But now you can get standalone LCD monitors for $100, that will "just work".
    Granted I am biased. I almost always buy new because a) it's for pay projects b) it has to work c) don't have time to refurb things.
    If fixing up an old laptop is a hobby, ie, you can spend several weekends on it as a fun thing to do, then go for it. Personally I can't recommend it.
  • draziw
    draziw over 11 years ago in reply to benheck
    Hello, I have the same TX2000 screen that I want to use in my CarPC installation. I know you said that you could get a monitor or touch screen for cheap, I do have a 7" TS but I won't get the resolution as I would with the TX2000 display. I've searched and asked for a schematic but havn't received any response. If your familiar with the Display, you know it has camera, mics, controls for media control. My goal is to use the front end Centrafuse to control all. Maybe you can point me in the right direction, where I might find the pin out for the display.
