element14's The Ben Heck Show
Forum Mini ITX DIY laptop project
  • Subscribers 31 subscribers
  • Views 1122 views
Hi ben!
I was thinking about an Mini ITX laptop, so building a PC is easy but how to get the power?
maybe ben or someone else could help me?
Ive read something about DC to DC ?
But what power source should I use?
  • andrewk182
    andrewk182 over 13 years ago
    DC power pak, but I would have to know the power need's for the computer before I say anymore.
    e14 Contributor over 13 years ago in reply to andrewk182
    I have chosen this setup:
    -  Asrock FM2A75M- ITX
    - AMD A10 5800k
    - ValueRAM 2 x 3 GB
    - WD scrorpio black  750 GB 7200 rpm
    - SANDISK ReadyCache 32 GB SSD for windows ( OPTIONAL )
    - some small fans
    I took eXtreme power supply calculator and got minimun PSU Wattage : 155 W and Recomend Wattage is 205 W
    Ow And it also has to power an LCD screen
    But it will be a little bit oversized laptop but I hope to get atleast 3 / 4 hours on the go with it.
    Thanks in advance
  • jds123
    jds123 over 13 years ago in reply to e14 Contributor
    You should invest in some higher quality lithium ion batterys, however it will probably take up a lot of space if you want to get 3-4 hours. Make sure the power output of the batteries match the power input of the computer, because otherwise you will have to deal with power conversions. Make sure to take into account the screen's draw on the battery, and ALWAYS make sure to have the proper charging board.
    I have wanted to do/see something like this for a long time! What is you made a case for it that had the batteries in it. That way if you are not near an outlet you can use the power from the case and the actuall laptop wouldnt weigh as much. Kinda new at this so please feel free to poke holes!
    P.S. I'm a fan of the APU
    Hey I am also an fan of the APU
    But now I think it would be better to buy and laptop motherboard and connect other ''attachments'' to it
    because the mini itx mobo is in total like 45 cm high thats pretty big for an portable laptop this days.
    so maybe and i5 mobo from an laptop and an old LCD screen ? and then fit it into an custom case image
    - AMD A10 5800k
    - ValueRAM 2 x 3 GB
    - some small fans
    Thanks in advance
    32gb ssd would be to small because some programs you can only install on drive where windows are, in your place i would use atleast 80-120gb ssd for windows
