element14's The Ben Heck Show
Forum amperage
  • Replies 11 replies
  • Subscribers 31 subscribers
  • Views 5609 views
amperage
franksterb92
franksterb92 over 13 years ago
so im building a combo nes snes n64 and gamecube and ill be using a atx power suppliy to power the consols my question is dose the amprage have to be right on for what the console requirers or can it be a little higher .
  • franksterb92
    franksterb92 over 5 years ago +1
    wow 8 years of electronics hobby designing later i have come so far from thinking i had to place resistors in series with the output of a linear reg lolz
  • Andrew J
    Andrew J over 5 years ago in reply to franksterb92 +1
    So did you get those consoles built and did you need heat sinks? Feels like an episode of a soap . It was only a couple of years ago that I thought a LM7805 was a type of helicopter.
  • colecago
    colecago over 13 years ago
    It should be higher.  If you have the voltage right, the consoles will only pull what they need.  Just because you can support more doesn't mean you are forcing that current into your system.
  • franksterb92
    franksterb92 over 13 years ago in reply to colecago
    thanks a bunch im new to this kinda thing and i was confused on the matter thanks again
  • franksterb92
    franksterb92 over 13 years ago in reply to franksterb92
    see the gamecube and n64 use 12v but i need to change there amperage i plan to use resistors to achive this and with the nes an snes i need to regulate there voltage im gonna use a l7809 volt regulater and l7810 for them do you think this is gonna be a good plan
  • colecago
    colecago over 13 years ago in reply to franksterb92
    You don't need to change their amperage.  You need to make sure your 12V line can handle the amperage they need, and they will only draw what amperage they need.
    Think of it like this, you plug in lamp to your wall outlet.  It will draw a certain current at 120VAC.  You unplug it and plug in your fridge, it will draw much more current, but still at 120VAC.  Your outlet provides what they need as long as it's able, it doesn't regulate the current in any way (until it gets overloaded).
    As for the voltage regulators, just make sure they can support the currents you need.  I have no idea what the draw on the NES and SNES are.  Usually the regulators are rated in power, so take the input voltage minus the output voltage, that will be the voltage dropped across the regulator, multiply that by the estimated current needed to get the power the regulator will see.  You will probably need a heatsink, I imagine the NES and SNES draw over an amp.
  • franksterb92
    ok ic thanks again ive ben tying to put this together for a wile now an was worried about the amperage but since i only have to worrie about the voltage thats good beacuse i undersand that part. the nes runs off 9v 1.3 amps and the snes runs of 10v 850 ma , i watched an episode of the ben heck show an was inspired to learn more about electronic circuits an decided to build this console thanks for the help i was lost on this again im new at this an need to learn more image
  • colecago
    I'd shoot for at least 2-2.5A on the 9V one and on the 10V one go for 1.5A.
    Maybe these
    9V - http://www.newark.com/stmicroelectronics/l78s09cv/ic-v-reg-2a-9-0v-78s09-to-220-3/dp/26M0570?Ntt=L78S09
    10V - http://www.newark.com/stmicroelectronics/l78s10cv/ldo-fixed-10v-2a-15v-to-220-3/dp/26M0571?Ntt=L78S10
    You might still need to heatsink, you'll have to test that.
    http://www.newark.com/wakefield-solutions/274-1ab/heat-sink/dp/50B8304
  • colecago
    Oh, and remember output capacitors on the linear regulators.  I got burned by that before.  I figured I didn't care if my output had ripple so I didn't use a cap and my regulator started oscillating.  There is usually a minimum capacitance specced.
  • franksterb92
    thanks for the help im going to order the parts i looked at the data sheet for both regulaters and found the capacitors i need for input and output looks like this thing might accualy get put together
  • franksterb92
  • Andrew J
    So did you get those consoles built and did you need heat sinks?  Feels like an episode of a soap image.  It was only a couple of years ago that I thought a LM7805 was a type of helicopter.
