element14's The Ben Heck Show
Forum Alternative Keyboard for Pocket BASIC Computer
  • Replies 9 replies
  • Subscribers 34 subscribers
  • Views 1073 views
  • 360
  • mod
  • viewer
  • portable
  • hardware
  • build
  • idea
  • help_required
  • ben_heck
  • ben
Hi guys,
Are there any alternatives to the xbox chatpad in the Pocket BASIC Computer e.g. one that interfaces with the arduino's RX pin without being programmed manually?
Usama
  • rhyse302
    rhyse302 over 13 years ago
    If you go onto the Newark site in the raspberry pi section there is a mini keyboard that is make for the pi so it should work.
  • colecago
    colecago over 13 years ago in reply to rhyse302
    Is the mini keyboard for the Pi USB?  If so it wouldn't be plug in play compatible with an Arduino. He was looking at the chatpad options which uses serial which is a lot more Arduino friendly
    Thanks Rhyse, but I was looking at keyboards which use serial...
  • rhyse302
    rhyse302 over 13 years ago in reply to e14 Contributor
    No problem! I was looking dor one for a long time to. Glad I could help.
    You could use a tiny PS/2 keyboard and use a serial converter or use this portable one from ebay: Stowaway Portable Keyboard Designed by Think Outside RS232 Direct P N ES17000 | eBay
  • royston02
    royston02 over 12 years ago in reply to e14 Contributor
    Ps/2 keyboards are big.He meant a pocket computer and only require small ones(unless willing to comprmise on the size). If used with RPI there are many options. If you can't find one, best thing is to laser cut the keys and use a switch(which will require programming).
  • mayermakes
    mayermakes over 12 years ago
    You could also use only the pcb  of a ps/2 keyboard and make a small matrix with small tactile switches (just only for the keys you need) . its just a lot of work to figure out the connections on the keyboards pcb.
    ..going further: you could add a ps/2 connector on the outside of your Pocket computer and use your pocket computer as keyboard of a regular PC. like Dual-typing in both units at the same time...--> this way you could simultaniously write BASIC code, and "record" it on your pc.
  • kidiccurus
    kidiccurus over 12 years ago in reply to mayermakes
    I think that a chatpad is probably the only option unless you multiplex some tact switches and make your own.
    couldn't you get an RPI mini keyboard and mod it? it already has the physical buttons in a matrix, you'd just need to exchange the USB controller for a serial one, assuming that the keyboard layout matrices are the same (I'd imagine they're pretty universal but I might be wrong)
