element14's The Ben Heck Show
Forum Hard coating for sintra (expanded foam pvc)?
  • Subscribers 29 subscribers
  • Views 889 views
  • sintra
  • ben_heck
  • construction
  • case
After seeing it on the show, I have been cnc routing enclosures out of Sintra. I was using hdpe but it required a lot of hand finishing, the finish of Sintra is perfect right off of the machine. The only problem (which makes it great to machine) is that it is soft, so it dents easily, e.g. with a fingernail. Does anyone have any suggestions for coating the Sintra with something that will harden it up a bit?
Any suggestions are greatly appreciated. Thank you
    dougw over 12 years ago
    Hi Mark,
    You might try polyester resin (used for fiberglass) - available in automotive repair departments or boating supplies or surfboard shops..
    Various "fillers" are available for these resins if you need special properties.
    (Try a test piece first)
    Doug
    e14 Contributor over 12 years ago in reply to dougw
    Thank you very much. I will experiment with that.
