element14's The Ben Heck Show
Forum Telephone Rotary Dial relay control
  • Replies 12 replies
  • Subscribers 31 subscribers
  • Views 1961 views
  • rotary
  • control
  • telephone
  • dial
  • relay
Hey Ben,
I'm new here to Element14.com and just made an account.  I came here by watching your videos and thought that I would check it out.  I have a challange for you.  I was wondering if there is some way to make an old telephone rotary dial activate 10 different relays.  Let me explain:
If for instance I dial a 2 on the rotary dial, it will activate relay two, dial a three and activates relay three, and so on.  I would need this to pulse the respective relay (turn the relay on for about 250ms then shut it off)  I know this is a bit obscure, but there is a method to my madness lol image
    mcb1 over 12 years ago in reply to shabaz +1
    You could check out this one. https://www.sparkfun.com/tutorials/51 I think there was a kit at one stage Mark
    That must have looked very "James Bond"! :-) more 'Get Smart' If you want to see a really big dial, check out this one. http://www.thecoralsnake.com/History22 This one is in NZ now (less the dial). Had…
    All outputs will ripple through one-by-one, so that may be undesirable for some scenarios Simply inhibit the voltage that drives the relay until until after x and problem gone. When you want the 'relay…
    shabaz over 12 years ago in reply to mcb1
    I remember the 4017 was quite a useful thing, It is a decade counter with individual outputs, and a reset input. So if the reset could be arranged somehow using one pair of contacts on the rotary dial, and some debouncer (think a 555 can be used for that) for the count input should work. All outputs will ripple through one-by-one, so that may be undesirable for some scenarios. To prevent that, it could be latched using a register perhaps.
    Alternatively an arduino (but less fun ; ).
    When you want the 'relay' to stop, then the same timer arrangement drops the power, and they are off.
    Sometimes hardware solutions are simple ... but they are fixed.
    I'm thinking that a Digispark could easily provide the timer/control parts, while the 4017 selsinork suggests does the decoding.
