element14's The Ben Heck Show
Forum RPi question
  • Replies 7 replies
  • Subscribers 31 subscribers
  • Views 824 views
RPi question
royston02
royston02 over 12 years ago
I wanted to know if I can get audio from the HDMI port of the RPi to connect to external speakers and if yes then to which pins should I solder.
  • Gough Lui
    Gough Lui over 12 years ago
    Audio from the HDMI port is digital, embedded in the data stream. It's not possible to simply extract this for use with external speakers by soldering pins to my knowledge. There are external HDMI to VGA converters with Audio Output from the decoder itself, so you can use the HDMI audio, otherwise, home theatre HDMI receivers should be able to receive the audio from the HDMI port while passing the HDMI video signal for a TV to use.
  • colecago
    colecago over 12 years ago
    http://www.amazon.com/ViewHD-Premium-Audio-Extractor-Converter/dp/B00AHS8LD8/ref=sr_1_1?ie=UTF8&qid=1397412288&sr=8-1&keywords=hdmi+audio
  • royston02
    royston02 over 12 years ago in reply to colecago
    I need something to fit in my Pi and I am using a DVI-d monitor.
  • colecago
    colecago over 12 years ago in reply to royston02
    Fit in your Pi?  I don't understand.
    Why not just use the Pi's already analog audio output, the 3.5mm headphone jack.  You can solder to that and go to speakers.  The HDMI needs a digital extractor to get the audio data out, hence the box I posted.
  • royston02
    Sorry Pi portable. secondly i want to leave the audio port as it is in order to plug other accessories so I thought of using HDMI audio.
  • colecago
    It is what it is, to get the hdmi audio, you have to convert it from the digital stream, hence extra circuitry.  Another option is to use the Audio capability on the Pi breakout header, I don't know much about it besides that its mono I believe, and not very good.  You should check into that.
  • Gough Lui
    Gough Lui over 12 years ago in reply to colecago
    The audio GPIO pins are on the new P5 header, which is available on the Revision 2 Pi boards, and are not fitted with header pins. The P5 header itself conveys I2S signals - digital signals intended to drive audio codecs. At the moment, the only product I know that uses it is the Wolfson Audio Card (http://au.element14.com/wolfson-microelectronics/wolfson-audio-card/audio-card-for-use-with-raspberry/dp/2347264?MER=MER-T2C-HBNR-AP-WFSPIAC-72071) which has audio in/out, but I'm not sure if the software will meet your expectations (as it's still being refined).
