element14's The Ben Heck Show
Forum portable pi help
  • Replies 8 replies
  • Subscribers 31 subscribers
  • Views 786 views
portable pi help
hi, i watch your youtube on your portable pi and love it so much i wanted to make one. sad i am at a dead end and have no help figure out the battery system i like to do.
my problem is i want to power the pi, keyboard, wiki, and monitor. the RPi and usb stuff i want to run off a OKI-78SR-5/1.5-W36-C OKI-78SR-5/1.5-W36-C Murata Power Solutions | Mouser.
the monitor on the other is rate for 12v at .5 amp. the battery i been looking is a li-ion 11.1V 7800mAh which i was thinking a step up/down 12v could handle that, here is one i found Pololu 12V Step-Up/Step-Down Voltage Regulator S18V20F12, the only problem with that one is it output is 12v @ 2 amps, not sure if that's way too much?
finally the last problem i am having is recharge this thing. i am outdoor 12 hours a day. in the sun. the battery i been at is 9 cylindrical (18650) cell 2600mAh at 3.7v. i like to make a solar charge for it.
your fan, Chance
thanks
  • royston02
    royston02 over 12 years ago
    What size monitor do you want?
    e14 Contributor over 12 years ago in reply to royston02
    TThe monitor I got is 7 inches 7 Inch Tft Color Lcd Car Rear View Camera Monitor Support Rotating The Screen And 2 Av Inputs:Amazon:Car Electronics
  • royston02
    royston02 over 12 years ago in reply to e14 Contributor
    hope these help
    -http://www.ebay.com/itm/AT070TN90-LCD-Screen-Display-Monitor-Raspberry-Pi-Driver-Board-HDMI-VGA-2AV-/111362132437?pt=US_Car_Audio_Video_Dashboard_Installation_Kits&hash=item19edb349d5
    -http://www.ebay.com/itm/Diy-Monitor-for-Raspberry-Pi-HDMI-VGA-2AV-Lcd-Driver-7-AT070TN92-Touch-Screen-/121119934991?pt=US_Server_Boards&hash=item1c334f8a0f
    -7inch HDMI Monitor Kit N070ICG 1280 800 IPS LCD for PS3 Xbox360 Raspberry Pi | eBay-
    Touchscreen's better than normal.
    thanks ya'll, well right now i am in the air. 7 Inch Tft Color Lcd Car Rear View Camera Monitor Support Rotating The Screen And 2 Av Inputs:Amazon:Car Electronics is an ok monitor but adafruit has a 7 monitor 720p with audio which is nice https://www.adafruit.com/products/1667
    my problem is power the adafruit monitor needs 9volt at 1amp. my pi needs a good bit of power, i have wifi usb, RF usb for keybroad, and usb memory stick. also my wireless keybroad rechargers by usb too.
    my battery is 11.1v 7800mah li-ion. pack this all in a little case B&W International Type 1000 Outdoor Case - Tool Experts
    i also like to have solar mount on the case. i need help building this power supple battery thing.
    About the current problem you have you could calculate a resistor with Ohms law to limit the amps for the screen then use a 5v regulator to power the PI. If you do not know about Ohms law yet search Make presents Ohms law on YouTube I hope it helps you.
  • colecago
    colecago over 12 years ago in reply to e14 Contributor
    Adafruit monitor is 9-12V, minimum is 9.  I would just go straight off the battery for that one and see how it goes.  For the Pi, you will need a 5V buck converter.  You can search around for one, or you can try and use a Car USB adapter if it has enough juice, not sure if it will though, you probably want 10W minimum output.
    5V USB DC 7V 24V to 5V 3A Step Down Buck KIS3R33S Module Arduino Than LM2596 | eBay
    You could use a voltage regulator for before it gets to the pi, and have the LCD power supply go to the regular 12V.  Be careful with the voltage regulator and chose the right one.  Try to find the tech time out on voltage regulators.  They have what is called a dropout, which is when the regulator doesn't give any voltage out.
  • colecago
    If you use a regulator, use a switching regulator like I mentioned, a buck regulator.  A linear regulator, which Ben uses a lot on Arduino's and such, are too lossy for high currents.  At 11V input and 2A out at 5V, that's 14W wasted which will burn up most of the regulators you'll use.  A switching regulator like this one
    http://www.newark.com/murata-power-solutions/78sr-5-2-c/ic-sync-switching-regulator-sip/dp/40M6586
    Might cut it, or it might now, you seem to want a lot of peripherals attached to your Pi.
